Battery Problem?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2007, 11:08 AM   #1 (permalink)
View sonyminidiscman's Photo Gallery
Battery Problem??
Hi, maybe you guys can confirm my findings or suggest new things.
over night, my battery seem to have just died, i tried to start it yesterday morning, i hear a click and nothing else, so i use an external battery, jump started with no problem... same thing after work....
So I took a voltmeter, did some testing:
Car Idle, battery is 12.96V
Car just turned off, 12.96V after 20 min, 12.80V
Disconnected -ve terminal, left over night, in the morning, 12.30V
When i tried to start it this morning, its sounded like theres not enough battery, so does that mean my battery just died over night? or can it be something else.
94 corolla
http://www.cardomain.com/id/sonyminidiscman
sonyminidiscman is offline   Reply With Quote
Old 04-26-2007, 01:08 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
First of all, you should be having 13-14.4V coming out of your alternator. Second, sounds more like you have a short, or something thats causing the battery to drain... Although a battery can break over night even. So dont count that out either, you can get the battery tested.
Flashmn is online now   Reply With Quote
Old 04-27-2007, 12:35 AM   #3 (permalink)
Oh man, i spend about 5 hrs today.......... trying to find that short, i know it exists.... but i can't find it............ i took out all the fuse that I don't think i need, like dome lights and cigareet lighter, radio,
and i see it still draining like 0.01V every minute.................. what else can i do???
94 corolla
Old 04-27-2007, 08:20 AM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
do this.... test the amp load on the battery when the car is off and all the accesories are turned off... just like u leave it overnight.... there should be no more than a 2mA load on it... if u get that load then its your battery... also what u can do, before u park ur car for the night, take the battery completely out, and put it back in the morning, and if the car still dont start u know its the battery that is bad
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-27-2007, 10:03 AM   #5 (permalink)
Oh thats right......stupid me............ i didn't even think of checking the current....... looked at the stupid voltage for 5 hrs..............thanks!
94 corolla
1992 Lexus Es300 ABS Problem Anovice Camry & Solara Lounge 6 10-13-2006 08:32 PM
Problem with battery terminal Curry Audio, Video, and Security - Tech 9 09-27-2006 10:06 PM
Toyota Corolla 2000 LE - battery problem? hyankov Archived Corolla threads 4 09-09-2006 02:20 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 10:21 PM
battery problem...or something else? tankpower2 Camry & Solara Lounge 5 10-11-2005 08:33 PM
