Just did a head gasket replace on my 92.
Place the crankshaft at top dead center, pointer lined up to the "0" on the cover. Make sure that the #1 piston is at the top if not then rotate 360 deg until piston is at the top. The exhaust camshaft gear key should point to the top at 12 oclock. There is a dimple on the ex. cam at 9 0clock and should match the dimple on the 3 oclock intake camshaft. This is the Top Dead Center position and timing of camshaft to crankshaft.
When the intake camshaft is removed the meshed spyder gear should be locked with a 6mm bolt before removal to prevent the mis alignment of the 2 piece gear. The gear cannot be locked in the TDC position and the ex. cam has to be rotated cc so that the 12 oclock pin is rotated just below 9 oclock. This will place the bolt opening on the intake cam to 12 oclock to insert the 6mm lock bolt.
Pix Top Dead Center
Intake Cam Lock bolt hole at 12:00
