Hello all, I'm new here, but I just wanted to get a bit of advice from some of the gurus. I'm new to Toyota's in general, but I have lots of experience in mechanical, eletrical, and other automotive maintenance.
I just bought a '94 Toyota Corolla. It's in excellent shape inside and out. Everything on it works (except for the center console lights on the climate controls). Here's the pertinent info on it:
- 1.8L
- DX Sedan
- Automatic Transmission
- 196K miles
- Bone Stock on everything
I just purchased it, and had a couple of immediate issues fixed:
- Replaced motor mounts (one was cracked)
- Replaced a broken valve with 2 vacuum lines (not sure what it was called, some kind of cold-start valve).
- Replaced coolant hose that was leaking
- Installed 4 brand new tires
- Changed oil
- Got it inspected
The only other issue with the vehicle is that all four interior door handles are broken in exactly the same spot. They all work except for the passenger side front door. I have ordered 4 replacements and will be installing those as soon as they get here.
Just as an FYI, here are my other mods I have planned for the next week or so:
- Replace all four speakers
- Install an Alpine head unit with iPod control
- Possibly install alarm or at least remote keyless entry
- Replace window tinting as the back window is bubbling slightly and the door windows are beginning to show the first signs of purpling up
- Install some wheels (nothing too fancy here, but I lost a wheel cover on it already, and I hate wheel covers anyway)
- New floor mats (the ones that are there suck!)
I have also made an appointment to have my mechanic replace the timing belt and water pump on Monday, just to be sure, but are there any other suggestions you might have as to what maintenance items should be looked at besides what I have done, or planned to have done? The belts seem to be in good shape, the transmission shifts perfectly, and the car passed the Texas state emissions test for Dallas / Fort Worth, so it seems to be running well with regards to that. I just want her to last quite a bit longer. The previous owner seems to have taken remarkably good care of the car, as it really is super clean inside and out.
TIA!
Edit: I forgot to add that the car is a one-owner.
