AE92 No Spark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 07:33 PM   #1 (permalink)
View allmtr86's Photo Gallery
AE92 No Spark
OK, got a ae92 that has no spark. Situation is the car turns over but wont start. So i checked for fuel, got it, next was spark, got none. Also checked if i would get spark from the coil to eliminate the distributor as the cause, but got none from the coil.
Checked the igniter, thats good.
Checked the Voltage to the Coil, thats good.
Checked Distributor, thats good.
I see it as the ECU being the only option, but some other suggestions would be appreicated. Also would a 89 n/a ecu work on the ae92? Because i tried that ecu on the ae92 and that didnt work either. Thank you in advance.
allmtr86 is offline   Reply With Quote
Old 04-27-2007, 08:11 PM   #2 (permalink)
View madking411's Photo Gallery
check your plugs too. Similar thing happened to me yesterday..went through a whole lotta trouble in trying to MAKE the car drive, and then i finally called the mechanic...turns out thts all i needed.
madking411 is offline   Reply With Quote
Old 04-27-2007, 10:29 PM   #3 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
Check out
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Autozone engine electrical
91boz is offline   Reply With Quote
Old 04-28-2007, 06:05 AM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Check the MAP sensor vacuum line for cracks, especially if it has that spyral wrap on it. No vacuum = no spark.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 04-28-2007, 06:21 AM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
There are resistance checks (using an ohmeter) you can perform on the coil to verify if it is faulty. Just having 12 volts going to it doesn't rule it out. Check out a manual from your library for the specs and procedure to check it. I had a Celica with no spark and it turned out to be the coil. Don't forget to check the distributor cap/wires and rotor too.
90 GP is offline   Reply With Quote
Old 04-28-2007, 06:25 AM   #6 (permalink)
Another thought is the timing belt. Did you remove the distibutor cap and have someone crank car while watching to see if distributor rotor moves? If it doesn't it is the timing belt.
Old 04-28-2007, 02:36 PM   #7 (permalink)
the car is a 89 gts, so it does not have a map sensor it has a AFM, so i tried a different AFM and that did not work.
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
Spark plugs for AE92 ultimax5 Archived Corolla threads 4 07-08-2005 10:53 AM
ae92: spark plug gap halforc Archived Corolla threads 2 12-15-2004 03:02 AM
AE92 no spark problem - HELP !! dwake122 Hardcore Tech and Competition 5 03-11-2004 02:05 PM
