AE92 Coolant Drain Plug? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2007, 09:03 PM   #1 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
Where is the engine coolant drain plug located? I recall seeing a diagram showing it to be located under the exhaust manifold on the block but I do not see a plug there.
91boz is offline   Reply With Quote
Old 04-28-2007, 12:05 AM   #2 (permalink)
Danno
View 89yotarollagts's Photo Gallery
?? im not sure what your asken about but i drain my coolent from the bottom of my radiator through a lil wing nut type deal..
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 04-28-2007, 01:30 AM   #3 (permalink)
92 Corolla 4AFE
Question
Yes, that is the radiator drain but I am looking for the engine block drain plug. Most cars have a drain plug on the engine block to drain out the rest of the coolant that doesn't come out of the radiator.
Old 04-28-2007, 08:20 AM   #4 (permalink)
View madking411's Photo Gallery
hey, i think its not underneath the exhaust manifold. its located next to the oil filter....but you might not notice it RIGHT away....in the haynes repairmanual, they have the oilfilter removed so you can see the engineblock drainplug better in the picture. so i guess, if you want to go through it, go ahead and drain ur oil, and remove the oilfilter if you dont notice the coolant drain...(?)
madking411 is offline   Reply With Quote
Old 04-28-2007, 02:43 PM   #5 (permalink)
92 Corolla 4AFE
Thanks I'll check it out!
Old 04-28-2007, 04:14 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Yeah I came across it when I had the head off Would never notice it without the exhaust manifold out of the way, at least not from the top
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-28-2007, 04:19 PM   #7 (permalink)
Danno
so whats the point of doing this ? Rather than a good flush & refill ?
Old 04-28-2007, 04:52 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
its for draining the coolant out of the block.
Old 04-28-2007, 04:57 PM   #9 (permalink)
Danno
i understand that but wouldnt all the old crap come out of the block when you flush the system ?
Old 04-28-2007, 06:10 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
yes and no, thermostat housing is higher up than the drain plug.
Old 04-28-2007, 11:01 PM   #11 (permalink)
92 Corolla 4AFE
Thanks for the help guys. I just had the head rebuilt but never thought of looking for the plug when the exhaust was off.
Is it closer yo the filter or towards the center of the block?
Old 04-29-2007, 05:45 AM   #12 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
YOu are aware some models of Toyota have an issue that when you drain coolant and fil with coolant that air pockets can develop and can result in the temperature sensors not working properly. You must make sure you don't have any air pockets in the cooling system, after doing maintanence. I know there are instructions on this somewhere, I just can't remember the Toyota models and where this info is located, and on which websites and which manuals. Maybwe somone can refresh our memories where to look for this info. I was used to the big American cars and enver heard of this till I had a foreign car. In fact I once had this happen to me. The snesors actually went wacky a few weeks after I had chaged the radiator. I believe I didn't do the procedure correctly and caused air pockets which made the snensors readings and even made the fans go crazy with the bad sensor readings...
I just thought I would bring this up, the thread looked appropriate..
retiredat44 is offline   Reply With Quote
Old 04-29-2007, 07:59 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Just cycle the thermostat when you change the coolant, a corolla will self-purge the air.
However, retired is right about the sensors not working when theres air... lol... lost the coolant once in my engine and drove because the temp sensor didnt move.. then suddenly BAM full hot.
Old 04-29-2007, 10:43 AM   #14 (permalink)
92 Corolla 4AFE
Yes I am aware of bleeding the air out of the cooling system. My wife drives an Accura Legend and it is very critical to bleed the cooling system. Air pockets will false trigger sensors and all kinds of symptoms from idle fluctuation to no heater operation. I agree the Corolla self purges itself of air pockets. The manual shows no bleed screw that I am aware of.
Old 04-29-2007, 02:58 PM   #15 (permalink)
Exclamation
Also, some cars, that are sold in certain regions of the world where it is very cold, the standard options may include block heaters, drains plugs and more, that a car in a mild climate might never have.
Rear Diff oil blues.... pdx 2nd Generation (2005+) 214 07-18-2010 05:00 PM
Drain Coolant from 1998 Camry LE 4 Cyclinder geomac 3rd & 4th Generation (1992–1996 & 1997–2001) 10 02-18-2007 01:24 PM
Draining Coolant: engine drain plug?? boogleking 1st & 2nd Generation (1983–1986 & 1987-1991) 9 02-04-2007 04:07 PM
1zzfe coolant drain plug on the engine block xzhuang Archived Corolla threads 5 01-10-2007 12:28 PM
Socket size of oil pan drain plug Kooter Camry & Solara Lounge 4 10-17-2003 08:14 PM
