filling up at the gas pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2007, 11:02 AM   #1 (permalink)
View josett's Photo Gallery
2003 toyota corolla, whenever I fillup at the gas station the car starts but will not idle. after about 6 attempts the car will throttle, and the problem never happens again until the next visit to the pump.There is no CE
Thanks
josett is offline   Reply With Quote
Old 04-29-2007, 09:11 PM   #2 (permalink)
View wheredoesthisgo's Photo Gallery
Turn your gas tank cap until it cliks when your done fueling. Please reply if this worked.
wheredoesthisgo is offline   Reply With Quote
Old 04-30-2007, 05:59 AM   #3 (permalink)
Tried that, replaced cap, did not work, in any case the Ce light would come on if cap was not fully tightened
Old 04-30-2007, 02:13 PM   #4 (permalink)
View DoubleEdgedWomb's Photo Gallery
Check your fuel filter. Maybe you're stirring up some sort of crud in the tank that's blocking fuel flow until it settles.
DoubleEdgedWomb is offline   Reply With Quote
Old 04-30-2007, 05:15 PM   #5 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Thanks
maybe the pump is located in the tank and for some reason, when you fil it the fuel upsets some component in the fuel tank.
retiredat44 is offline   Reply With Quote
Highlander Hybrid gas filling problem H Ball Toyota Highlander Hybrid 9 12-28-2011 08:33 PM
check your 07 camry for defective gas pump CamryXLE07 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-28-2006 11:30 AM
Gas Overflow When Filling Tank? Itisme 1st Generation (2003-2008) 8 07-21-2005 08:41 PM
