1993 DX AC problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2007, 01:02 PM   #1 (permalink)
View zaboss's Photo Gallery
1993 DX AC problem
Just got a 1993 corolla DX, Ac blows hot air, the compressor is not working, but the previous owner said, it is just a switch not the compressor. How can i check that. please help
Thank you.
zaboss is offline   Reply With Quote
Old 04-30-2007, 08:57 AM   #2 (permalink)
blb
View blb's Photo Gallery
Run a temporary jumper wire from the positive battery terminal to the wire going to the compressor clutch coil. If the compressor turns and sound fine, chances are, the compressor is good. Don't run it for too long wired this way. Because the compressor is protected from coming on when the refrigerant level is low, you may just be low on refrigerant.
blb is offline   Reply With Quote
Old 04-30-2007, 02:48 PM   #3 (permalink)
View darcsyde's Photo Gallery
yea if it's low on refrig. and since it's a 93 it might still be R12, be cheaper to retrofit unless u know someone that's willing to give up som R12 for cheap
darcsyde is offline   Reply With Quote
98 camry le v6: Trunk Lid light/ Back up lights not working, Problem and solution ihqazi 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-26-2009 01:01 AM
AC problem mykyna 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-04-2007 08:53 AM
Power Steering Problem 1993 Camry ss1670 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-21-2007 08:20 AM
AC system shot? Any advice? joneswak Archived Corolla threads 6 12-27-2006 01:19 PM
1993 Camry Transmission problem? CrackerJack 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-23-2004 09:13 AM
