ok. first off, when I said 'clutch' I meant 'choke'. I have an automatic, for the record.
also, I was just wondering your thoughts on this as well. it rained overnight, and I went to use the car in the evening (the ground was dry, but the air was heavy still). I pumped the gas twice, engaging the choke, and started the car.
You see the problem with the stalling only happens for the first few miles, then it runs like normal. So I decided to just let it just sit there and warm up until the choke clicked off before moving it. The engine went through its usual sounding wakeup stage (sputtering and slightly shaking the car, slowly winding up to a smooth high idle) and was running nice and strong. I put the vent on high for a little while too, thinking more airflow would help the engine air out.
the choke clicked off, and the car stalled. I try to start it back up again, but to no avail. I notice the starter is turning over a lot faster and lighter sounding/feeling compared to normal, like the engine's warm and should be running. the engine indeed was quite hot. When I finally got it to start about 10 minutes later, I had to pump the gas pedal several times while turning over. The engine 'fired up' a little with each pump, then finally started.
I had to keep keep shifting in and out of neutral while backing out and pulling out of the parking lot, but once I was on the road I was fine and didn't stall.
which actually brings me to a new question. why is it more likely for me to stall when I'm stopped and idling in 'drive' (even moreso if I go to accelerate from a dead stop), as opposed to idling stopped in neutral (and revving the engine slightly before putting it into drive to accelerate)?
I realize that this is just a webforum and that I'm better off going to a mechanic, I'm just curious.
