Brakes are very straightforward to change out yourself, and that would only cost you the cost of parts. I don't know what prices are in your neck of the woods, but here's what it would cost here:
Brake Pads: $19.99 (Lifetime warranty).
Brake Shoes: $14.99 (Lifetime warranty).
Turning rotors and drums: $28.00
Thats all you should need assuming there are no other issues. It is possible that your rotors / drums would not be machinable, in which case they would need to be replaced. You should also inspect / re-pack the bearings, which is nothing more than the cost of the bearing grease assuming they're in good shape.
A shop would probably charge anywhere from $150.00 - $200.00 to do the same thing. So, doing it yourself would be significantly cheaper and not really very difficult. The only recommendation I'd make is to use ceramic brake pads. They are really nice because they don't leave the residue that standard brake pads do, but they're slightly more expensive. Just my $.02. HTH!
'06 Toyota Sienna CE
