Head Gasket Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2007, 08:51 PM   #1 (permalink)
View wheredoesthisgo's Photo Gallery
Head Gasket Kit
Hello Folks. I am doing my first head gasket on a double overhead cam 4Afe. It sure would be nice if the manufacturers at Felpro labeled the seals in the bag. I dont know where some of these o rings go. I can identify 97% of everything there but I guess I ll find them when i pull the cams. Is there a head gasket kit part identifier out there? If I was having the top end done I guess the machine shop would put them all in. But this corolla only has 135,000 on it. I think I might just change the belt, pully, waterpump, and head gasket. Hence the name. Where does this go?
wheredoesthisgo is offline   Reply With Quote
Old 04-29-2007, 09:12 PM   #2 (permalink)
View OEMonkey's Photo Gallery
If it's a felpro headset kit, then it should come in a flimsy flat brown box. All the gaskets, seals, and orings are itemized on the box. If your taking the head to a machine shop, just give em the kit since your not sure what they'll need. I'm sure they can figure out which ones are the valve stem seals. Some of the Orings: injectors, distributor, water pump.
OEMonkey is offline   Reply With Quote
Time for a rebuild, just blew 1mz-fe head gasket trd4life Camry & Solara Lounge 9 04-29-2009 12:38 PM
Head Gasket 89toyota4x4 Tercel, Paseo, Starlet, and Sera Forum 17 07-21-2006 02:25 PM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
head gasket oil leak profuse007 Camry & Solara Lounge 2 07-27-2004 11:08 AM
