98 Corolla 1.8...fan problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2007, 03:53 PM   #1 (permalink)
View perro's Photo Gallery
Fan doesn't engage...I have replaced the heat sensor and the coolant sensor. The relays are good, and the fan motor actually works, but it just won't come on like it is supposed to so the car overheats. The thermostat is open and water is circulating, too, but the fan still won't come one. What else could be the problem? Any ideas?
perro is offline   Reply With Quote
Old 04-30-2007, 06:17 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Sounds like the thermostat is shut, the fan won't come on if the thermostat is not letting the coolant through to pick up the temp reading and turn the fan on.
change the thermostat and go from there.
Old 04-30-2007, 07:12 PM   #3 (permalink)
Oh, sorry, I should have mentioned that the thermostat IS open and the coolant is circulating (I edited my question to add this). It's weird, I can't figure it out. I tested the fan, the relays, and put in the new sensors, but still the fan won't come on.
Old 05-01-2007, 10:28 AM   #4 (permalink)
KDM is in
REN69's Avatar
Then it's the rad, probably plugged somewhere along the lines and it's not cooling properly OR the fins no longer cool the liquid, push the fins and see if they're brittle and fall off easily, if so then you need a new rad.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-01-2007, 03:23 PM   #5 (permalink)
If that's the case (bad radiator) wouldn't that STILL make the fan kick on (since I know the fan works- I have tested the fan and it runs)?
Old 05-01-2007, 09:14 PM   #6 (permalink)
KDM is in
REN69's Avatar
When my rad died, the fan never came on.
Old 05-01-2007, 09:53 PM   #7 (permalink)
Thanks!
99 Corolla intermittant starting problem wmcot Archived Corolla threads 9 05-18-2010 01:39 PM
1983 corolla overheating problem... mike5721947 Archived Corolla threads 5 05-26-2006 01:27 AM
98 Corolla Check Engine Light davedingman Archived Corolla threads 7 02-07-2005 04:14 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Check Engine Light on 98 corolla 240meowth Archived Corolla threads 0 07-24-2004 05:55 AM
