Basic maintenance questions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 03:42 PM   #1 (permalink)
View mike56's Photo Gallery
Hello,
Have an 03 corolla that just turned over 50,000. miles. Not a SINGLE problem.
Always change the oil under the 3000 mark, flushed transmission at 30k, and will do again at 60k.
Is there anything else I should be doing at this 50k mark ? Timing chain/belt?
You 100k guys, let me know please.
mike56 is offline   Reply With Quote
Old 07-07-2007, 10:30 PM   #2 (permalink)
View SkillzDoTcoM's Photo Gallery
I am not sure what to do at the 50k mark but at the 100k mark you need to change your timing belt and water pumps in the car for good maintenance.
SkillzDoTcoM is offline   Reply With Quote
Old 07-08-2007, 12:08 AM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
How are your brakes?
If you are hard on them, you might need new ones. I just hit 50,000 in my 01 and I have had to replace a set of pads and then get new rotors, pads, and my drums rebuilt.
If you need new brakes, you might want to check your tires as well.
also, don't forget to make sure your spare tire is at the correct PSI. (over infalte it a couple psi so you have some leeway)
Crowbar911 is offline   Reply With Quote
Old 07-08-2007, 12:10 AM   #4 (permalink)
View Tavel's Photo Gallery
the owner's manual should have a maintenance schedule, otherwise the haynes manual will definitly have it.
If you intend to do any work yourself, you should grab a haynes manual because it makes great reference. They're well known to be useless in most cases...but how else are you gonna know torque specs for the exhaust mainfold or something?
edit: crowbar is burning out his brakes at 50k??? holy crap, you must ride the brakes like a bicycle. I'm at 135k and still on original brakes....
Tavel is offline   Reply With Quote
Old 07-08-2007, 01:24 AM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Bad info there my friend
There's no "timing belt" in a 03 corolla it's a timing chain and doesn't need to be replaced at 100K...Also if your water pump is not leaking and working fine at 100K why replace it, that's just a waste of money!
Raddman is offline   Reply With Quote
Toyota Maintenance Records/History - website -? hotboi 5th & 6th Generation (2002-2006 & 2007-2011) 8 04-04-2007 12:44 AM
New here: introduction and a few questions sumptimwong Camry & Solara Lounge 19 04-20-2006 03:28 AM
2000 Echo, 150k miles. Two questions: clutch, and maintenance intervals theirongiant Yaris, Vitz and Echo Forum 2 04-10-2006 11:52 AM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
