Reuse Headbolts??? (94 corolla 1.8L) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 07:10 PM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
soon all will be revealed, but a another bump in the road, the Toyota service manual dosn't say you can't reuse the headbolts or doesn't have the diamond for "not reuseable" but most parts people say they need to be replaced soo???
I donno if i should use the old ones or not, BTW it is my car 94 corolla 1.8L .....
Also how does one know what bolts are reuseable or are of the TTY (torque to yeild / non reuseable) variety???
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 05-02-2007, 02:01 PM   #2 (permalink)
View darcsyde's Photo Gallery
the had bolts are TTY bolts, they should be replaced but i've known people to reuse them ONCE and then replace them
darcsyde is offline   Reply With Quote
Old 05-02-2007, 02:38 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
If they are TTY bolts, you cant reuse them. NEVER.
If people reuse them, well they're gonna have problems. The reason is that when you torque them, you stretch them to hold the head, well when they're stretched, they wont stretch another time.
Old 05-02-2007, 09:11 PM   #4 (permalink)
View 03mooncorolla's Photo Gallery
Flashmn Pretty much said it all, manual says replace them ( I would ).
Is it really worth taking the chance. Could lead to doing it again or worse
03mooncorolla is offline   Reply With Quote
Old 05-03-2007, 01:12 AM   #5 (permalink)
yeah i sorted out my little problem parts store shorted me one bolt in the set, i figured it would take a day or two to correct... but it only took a couple hours to fix so problem solved
Old 05-03-2007, 08:49 PM   #6 (permalink)
Gameroom cash: $134355
ok... here's the deal.... IF they are torque to yield (TTY) then there will be a torque tightening sequence where you have to go to each bolt, then 45 then 45 (or just then 90... depending on application)..... if the manual just says "torque to XX" and shows one sequence... then they are not TTY bolts....
in the case that they are not TTY bolts, you can reuse them... they aren't stretch bolts
Old 05-04-2007, 03:38 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, like i said in my previous post if they are TTY bolts then dont use them.
Old 05-04-2007, 08:29 AM   #8 (permalink)
View tashirosgt's Photo Gallery
It would be interesting to have a definite answer to 94_Rolla_Guy's question. For the '90-92 Corolla, the Toyota service manual says to tighten the head bolts, in a certain sequence, in several passes, to a definite torque. I don't have the book in front of me now, but it isn't an extremely large torque, something like 44 ft libs. As Rolla_Guy says, while many parts are marked as "not reusable", the head bolts are not marked this way. But as I recall, Chiltons gives directions along the lines of tightening to some smaller torque and then turning the bolts so many degrees. I trust the Toyota manual more than Chiltons, since much of the stuff in Chilton's is just general boilerplate that they repeat in all their books.
tashirosgt is offline   Reply With Quote
Old 05-04-2007, 10:00 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Torque to yield bolts are always tightened to a specific degree, it theres a torque reading as in 62NM/FT-LB/whatever, then they 99% likely are not stretching bolts.
Also looking at bolts would give you some clue as to wether they are stretching, if they have a narrow portion on the bolt, then they might be stretching bolts.
4A-F/FE on the AE92 are not stretch bolts and are not supposed to be tightened with a degree gauge. If you do that, chances are a)you have too much torque b)you fucked the threads of the block/bolt.
I'm probably using my headbolts for the 5th time by now (I lost count), next time I might go with studs.
Old 05-04-2007, 01:38 PM   #10 (permalink)
guess i was wrong always thought they were TTY bolts
What are the differences between a 94 Prizm & 94 Corolla?? toyloco Archived Corolla threads 9 11-19-2010 09:59 PM
Jiffy Lube messed up my '94 Corolla! jinster Archived Corolla threads 14 09-24-2006 07:51 AM
getting a 94 corolla, wondering how possible a 20vavle swap is josh..just josh Archived Corolla threads 11 05-01-2006 11:12 PM
'94 Corolla Axle Trouble fyrcap100 Archived Corolla threads 1 03-20-2006 11:58 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
