This is the Little Pig in my sig.
I rang up two shops that I go to for auto service and they both won't touch manual swaps, but would do shocks install for $300. So making my dreams come true with this little piggy will mean a major DIY project.
Car currently does not have plates or insurance, so it's down already and I can take my sweet time to do it right.
So, this is what I'm going to do to it:
1. Tell my dad I'm claiming it.
2. Build up a fund for insurance, plate and gas.
3a. Obtain a factory repair manual. My Haynes doesn't seem to do a good enough job.
DONE
3b. Find a manual tranny (C59) and all associated parts, including manual tranny ECU.
DONE
3c. If it isn't too costly over OEM fare, get a nice aftermarket clutch set and flywheel.
3d. Since I'll need a manual shifter anyway, get a TRD Shortshifter and shift knob. Shifter bag can be from crappy tire, I don't really care.
3e. Get a set of good quality springs.
4. Buy two more jack stands (I have 2), step drill bit aka unibit, badass 250lb/ft torque wrench and breaker bar.
DONE less breaker bar
4b. Write out a highly detailed action procedure, for every tiny little microscopic thing must go according to plan...
5. When all parts are on hand, rent a cherry picker engine hoist, break out electric impact wrench, and start the swap.
Note to self: Find something to hang the AC compressor securely out of the way.
Didn't drop the engine after all
6. With everything apart at the front end, might as well do a suspension upgrade too. Hello Tokico!
7. When swap is done, do suspension upgrade on rear end.
7a. If I feel like it, take the side window out and try a flawless tint.
8. With all mechanical swaps done, get insurance, 10-day permit, send it out for inspection and smog.
8a. If I can't get it out of the driveway without stalling, take a quick stick course for $60.
9. If all goes well, now I can arrange for the car to be transferred to my name.
10. After all this work, time to get an alarm installed and slap on some nice alloys. Kosei K1 TS in 14" isn't that bad hehe
That's Project Fulfullment. Turning THE Little Pig into MY Little Pig.
Thank you for reading. What do you think?
