Spark plug wires 4age newer style - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2007, 02:12 PM   #1 (permalink)
'88ROLLAGTS's Avatar
View '88ROLLAGTS's Photo Gallery
AE92 Spark plug wires 4age hi comp red top
First off I SEARCHED !! and found no help
Im doing a motor swap here in the next few weeks. I need a set of plug wires a cap and rotor for the new motor but I cant find the type I need. I went through this with my current motor and had a hell of a time finding the cap. I had to special order it because it was different than most american types.
This is the type of motor that is going in....
any help is appreciated
'88ROLLAGTS is offline   Reply With Quote
Old 05-14-2007, 02:29 PM   #2 (permalink)
okay so the pic thing doesnt work I guess.. This is the pic
http://bp1.blogger.com/_M86ELUAHA8w/...-GE16Valve.jpg
Old 05-14-2007, 02:32 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Dealership.
Old 05-14-2007, 02:36 PM   #4 (permalink)
the closest dealer is a long drive from me. I talked to them and got some young kid that couldnt understand the description I gave him.
I posted this to get a better idea of what it is or maybe a part number. The cover baffles me and I havent taken it off (at the shop) to see what it looks like under it. Im trying to get this info so that I can get a better deal on the wires and not pay the shop $120 for the wires they can get.
Old 05-14-2007, 08:28 PM   #5 (permalink)
AE92 Trueno n00b
deeoh's Avatar
View deeoh's Photo Gallery
AE92
That motor you bought is from the 90-91 Corolla GT-S. Also referred to as the high comp motor. Yes, the cap and wires are slightly different than the 88-89 TVIS motors. $46.99 for the cap and wire set at www.partsamerica.com Or if you have money burning a hole in your pocket, try the stealership...
deeoh is offline   Reply With Quote
Old 05-14-2007, 09:29 PM   #6 (permalink)
Gameroom cash: $134355
or you can do the smart thing.....
those caps suck ass... and the wires are the later toyota 5mm wires.....
here's what I did when I did my smallport swap....
get the cap and rotor from an older FWD 4age... might be the same as an ae86? dunno, just not the 4age cap style that has the wires going in every direction.... even dumber
then you can just get a set of "universal" 4 cylinder wires.... you have the spark plug valley cover to keep water out regardless.... I found a set in a box for $20 with a lifetime warranty... dunno the application, just started searchin....
Old 05-15-2007, 07:09 PM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's a redtop smallport 4AGE(90-91), having both bigport and smallport motors I can tell you the caps and wires are not the same, similar but not the same. Your best bet is to get the cap and wires from the dealership (drive there, you have no choice) or get them from an online toyota parts place (and hope you don't get ripped off).
Old 05-15-2007, 08:48 PM   #8 (permalink)
Red top huh? I was told that I didnt need to change ECU's is this correct?
Old 05-16-2007, 10:37 AM   #9 (permalink)
KDM is in
REN69's Avatar
I believe they're different part numbers for the ECU, don't quote me on this but I "think" you might be able to run it with the bigport (88-89) ECU.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-16-2007, 12:18 PM   #10 (permalink)
I sure hope so. The guys I have doing the swap for me (I miss my shop!) are confident that they can make it happen.
Anyone have any Ideas where I can get a good bushing kit and some cv axles that dont crap out at 6K miles??
Old 05-16-2007, 08:50 PM   #11 (permalink)
as for the cap.... contact points and hold-down points are identical.... IE you can use a bigport cap on a smallport motor....
the ecu's are different... the bigports run a different set of injectors, a different afm, and have t-vis than the smallport.....
you can run a smallport on bigport electronics... but you HAVE TO USE THE BIGPORT ELECTRONICS and strip the smallport of all it's electronics (including dizzy, coil/ignitor, etc...)... you will also have a "flat" spot in the rpm's where the ecu is expecting t-vis to come on
Old 05-17-2007, 02:06 AM   #12 (permalink)
If I had a ECU would I have to change the harness?
Spark plug wires and some help? decoro 1st Generation (1995.5–2004) 4 12-13-2005 11:39 AM
changing the spark plug wires on Gen 4 chesstompowell 3rd & 4th Generation (1992–1996 & 1997–2001) 13 11-15-2005 04:26 AM
remove spark plug wires from distributor cap pilot Camry & Solara Lounge 4 08-13-2005 06:28 PM
how to take off plug wires? 92camryguy04 Archived Corolla threads 3 04-18-2005 01:24 AM
