Average cost for timing belt change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2007, 11:41 AM   #1 (permalink)
View punkzcorolla's Photo Gallery
I have a 94 corolla; 1.6 engine.
What can I expect to pay for labor and parts for the timing belt? Should any other work be done at the same time?
punkzcorolla is offline   Reply With Quote
Old 05-15-2007, 12:34 PM   #2 (permalink)
View mvftw's Photo Gallery
Rule-of-Thumb is to change the Water Pump also. Then depending on when or if it was changed out, all belts and hoses, themostat... Plan on $300+. I always use a factory timing belt. Ask your guy if you can bring him a Toyota belt, he can use his own parts for the rest...
mvftw is offline   Reply With Quote
Old 05-15-2007, 01:49 PM   #3 (permalink)
hmmmm
Nutter's Avatar
View Nutter's Photo Gallery
I just had my timing belt, water pump, thermostat, and belts changed. Hoses were fine, and they flushed the coolant. This was about two weeks ago. The charge was $280 + tax. I didn't need new hoses because they had recently been replaced. That was in Texas. HTH!
'06 Toyota Sienna CE
Nutter is offline   Reply With Quote
Old 05-16-2007, 07:59 PM   #4 (permalink)
Banned
View raymundojr's Photo Gallery
Water pump and timing belt of mine has been changed at the same time and it cost me $250+ and other parts were also modified.My car has undergo several changes and i love the way it sounds.im satisfied now with BBK with a new hoses.
raymundojr is offline   Reply With Quote
Old 05-16-2007, 10:14 PM   #5 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
at what mileage should you get new water pump/hoses/timing belt/thermo?
vibebreaker is offline   Reply With Quote
Old 05-17-2007, 03:38 PM   #6 (permalink)
hmmmm
Nutter's Avatar
Well, normally you'd want to change the timing belt at around 60K miles. So that is a good time to replace the water pump and thermostat. As for other belts and such, those are easily inspected, so I'd replace them if they need it.
1990 AE92 timing belt change Valkyrie90AE92 Archived Corolla threads 7 01-26-2007 12:31 PM
Timing Belt Change jfarcas 1st Generation (1995-1999) 4 01-09-2007 09:29 PM
Timing belt change cost for Gen 3 V6? Keyser Soze 3rd & 4th Generation (1992–1996 & 1997–2001) 17 10-14-2006 09:44 PM
1990 LE - Timing Belt change - what else to change at the same time? Rubber Mounts? Gopal 1st & 2nd Generation (1983–1986 & 1987-1991) 2 06-28-2006 01:39 PM
