Trans or Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2007, 11:45 AM   #1 (permalink)
View elkiehound's Photo Gallery
Trans or Clutch
Today, my 160k mileage Corolla made a loud noise under the car while driving, It felt like the bottom dropped out, and was virtually undriveable. I was able to make it to the shop to park it (its sunday) driving very slowly in 2nd gear.
Despite the load noise, the engine light is not on and it is driveable, albeit slow. When I push in the clutch while idling, a "whining" noise goes away however if I disengage the clutch pedal while idling a whining noise is there.
The engine runs fine while idle, no kicking or stalling, however unable to engage the gear into reverse at all.
Any thoughts if this is a clutch replacement or transmission related is appreciated.
elkiehound is offline   Reply With Quote
Old 05-20-2007, 11:48 AM   #2 (permalink)
View 3S-GTE pRIZM's Photo Gallery
it sounds to me like you burnt reverse out some how. so that would be a tranny replacment
3S-GTE pRIZM is offline   Reply With Quote
Old 05-20-2007, 12:14 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Your best bet is to take it to a tranny shop who specializes in it because they can tell you right away what it is. Sometimes it's something as simple as a fluid change, yours sounds worse than that, but you never know.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-20-2007, 12:19 PM   #4 (permalink)
Yea, I parked it at the local mechanic shop. They will look at it in the morning.
I was thinking it was the clutch, have had recent "overthrow bearing" noise, however the loud sound under the body while driving makes me think otherwise. Not certain a clutch failure would make such a noise, yet it is driveable.
Hopefully, not a complete loss.
Thanks
Old 05-20-2007, 12:19 PM   #5 (permalink)
Thanks
Old 05-21-2007, 06:26 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
Thanks
"throw-out bearing" not "overthrow bearing"
If the clutch failed you would have no drive at all.
It sounds like your gearbox is eating itself. Not good!
I would suggest geting one from a salvage yard, that should cost you a lot less than a rebuild.
Good luck, let us know what the mechanic says.
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 05-21-2007, 06:56 PM   #7 (permalink)
Local shop sez its the transmission. Need to take it over to the trans man in town to see what the damage is to see if its worth the cost of repair. 160k miles, thinking if not too much, could get another 160k !
Thanks
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 01:17 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 06:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 08:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 05:16 PM
