Is the dealer trying to dupe me ? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 11:48 AM   #16 (permalink)
View bathukoli's Photo Gallery
Thanks a lot everyone. I will change the spark plugs (have'nt done it so far) and let you know. Thanks again.
bathukoli is offline   Reply With Quote
Old 05-22-2007, 12:07 PM   #17 (permalink)
View TomsGT4's Photo Gallery
'serpentine belt - tensioner seal' eh?
Sometimes translation gets lost between the tech & the service rep.
Especially when the rep doesn't know how to rotate their own tires.
Just ask the them to show you what seal it is in their repair manual, take you to the car & point to that location in the engine bay.
+1 for whom-ever mentioned removing the belt & turning the pulley by hand.
If it doesn't wobble and feels like it's spinning smoothly, then it's probably ok.
TomsGT4 is offline   Reply With Quote
Old 05-22-2007, 01:19 PM   #18 (permalink)
View toyomoho's Photo Gallery
Rockauto lists complete automatic belt tensioner units starting at around $50. If this is the problem DIY and save some money.
Old 05-23-2007, 01:35 AM   #19 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
I disagree with the bearing tensioner.. it goes by mielage, why risk a nightmare breakdown, of the tensioner going bad shorlty after you replace the belt. as, the tensioner is the main reason why the belt's break. better to spend the $60 now, then end up with a major breakdown because somone is too cheap to replace it now.
retiredat44 is offline   Reply With Quote
Old 05-23-2007, 09:04 AM   #20 (permalink)
$60? I want your prices...
I've paid $50 for one from a scrap yard here in Canada. Although it was for my Celica.
I think I recall my reaction when I found out what the dealer wanted for one.
I'm going to stick with "if it ain't broke... don't fix it".
Old 05-23-2007, 09:08 AM   #21 (permalink)
...although I do agree with fixing some things preventatively. Like doing left & right brake components at the same time.
Old 05-23-2007, 10:41 PM   #22 (permalink)
I bet that these stores ship to whereever you are, i fyou can't get thsoe prices where you are. But there is a good reason why they sell the bearing and belt together in a kit.
Old 07-12-2007, 08:16 PM   #23 (permalink)
View rdbrooke's Photo Gallery
Your plugs are Iridium and don't need to be changed until at least 100k.
Your Serp and tensioner probably need replaced.
rdbrooke is offline   Reply With Quote
Old 07-12-2007, 09:16 PM   #24 (permalink)
View Gsolo's Photo Gallery
wow....no one really knows what they are talking about....
At 60K miles yes the serp belt most likely needs replaced and on the 1ZZ engines most like your serp tensioner makes a little noise....and the oil leak is the timing chain tensioner!! Probably mis communication, either they said something wrong or you heard serpentine belt a couple tensioners and filled in your own blanks.
I recommend this stuff all the time and customers get bitchy about it. If you really think you're being ripped off then go somewhere else...just dont complain about your car dying later down the road.
And yes 1zzfe engines are notorious for leaking at the timing chain tensioner...you just get a new tensioner (comes with seal) and replace tensioner easy job cause its on the outside rear of left side of head near drive belt.
1990 Geo Prizm with Silvertop 20V swap
Toyota Tech
Gsolo is offline   Reply With Quote
Old 07-13-2007, 12:33 PM   #25 (permalink)
View rwstar03's Photo Gallery
Belt tensioner
I have a 99 Prizm ( same as Corrolla) and just replaced the serpentine belt tensioner because it had a rattling noise at take off and the belt would squeal occasionally. After reading several posts I ordered one off ebay for $69 delivered. That solved my problem. The tensioner has a shock absorber filled with oil and was leaking and let the belt jump around a lot. Now it is smooth. I have 127,000 miles on mine. It was easy to change if you have the right tools, less than an hour.
rwstar03 is offline   Reply With Quote
Dealer Cost vs. Dealer Invoice vs MSRP? doozer 2nd Generation (2005+) 27 02-25-2008 11:54 AM
need advice about dealer Jredneck480 2nd Generation (2005+) 6 02-15-2007 01:06 PM
Dealer fruad?? Voided warranty?? drycreek 5th & 6th Generation (2002-2006 & 2007-2011) 4 01-18-2007 11:39 AM
Do you have to pay dealer delivery or other dealer fees on Demo vehicles? NUKLEAR_AXIS 5th & 6th Generation (2002-2006 & 2007-2011) 3 01-12-2007 02:27 PM
XM Radio and Dealer Questions 92and06TOYS 2nd Generation (2005+) 8 11-10-2005 08:57 AM
