Adjusting headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2007, 04:00 PM   #1 (permalink)
View Tavel's Photo Gallery
I'm trying to adjust the headlights on my 2000 Corolla VE, they've gone askew over the years...but for the life of me can't figure out how to do it!
I see there's the weird adjuster wheel, but it will only spin 1 or 2 degrees in either direction and then it stops. I've tried using a wrench, screwdriver, even channel locks to spin the screw itself and it just won't move.
what am i missing here? Do i just need some penetrating oil or something?
And while i'm on the subject of lights, I'm replacing a cluster light soon and was wondering if there were any tricks to make the job easier/quicker.
Tavel is offline   Reply With Quote
Old 05-26-2007, 04:06 PM   #2 (permalink)
Bump.
No one has ever adjusted the headlights???
Old 05-26-2007, 06:41 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Check the user manual?
Old 05-26-2007, 10:27 PM   #4 (permalink)
BANNED
View w203's Photo Gallery
Which adjusting wheel did you adjust? The ones that changes the beam vertically and horizontally or the ones that changes the beam left and right? Can you take a pic of what your referring to? Did you have it parked on level surface within a few feet of a wall so you know where the beam is adjusting?
w203 is offline   Reply With Quote
Old 05-28-2007, 12:37 PM   #5 (permalink)
I believe I was trying to adjust the horizontal first, just to get a feel for how it works without cramping my hand reaching the bottom adjuster.
btw: I know how to properly aim headlights, I've done it numerous times. I just can't figure out how these particular adjustment mechanisms work.
This is the top adjuster (horizontal?). It only moves a few degrees in either direction. You can see my tool marks on the plastic nut.
That's the bottom one (vertical?). I don't think the screwdriver is engaging properly for some reason. The wheel won't turn at all.
Old 05-29-2007, 04:23 AM   #6 (permalink)
BANNED
Something could be stuck and preventing it from turning. Do you know if the other side headlight is having the same issue?
Old 05-29-2007, 10:31 AM   #7 (permalink)
yeah, they're both like that. should i try some wd-40?
adjusting the headlights...... roc 1st Generation (2003-2008) 4 01-07-2007 04:07 PM
Adjusting Tundra headlights big sur johnny Introduce Yourself Here 2 12-31-2005 05:18 PM
Adjusting headlights mikey13oi 1st Generation (1995.5–2004) 2 12-22-2005 11:16 AM
Adjusting headlights 83celicaGT Celica Forum 2 09-02-2005 03:37 AM
Adjusting Headlights on a Gen 3 Camry funboy102 3rd & 4th Generation (1992–1996 & 1997–2001) 5 02-22-2005 02:25 AM
