Bad Gas Mileage(thermostat sensor) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2007, 07:58 PM   #1 (permalink)
View aldwinenriquez's Photo Gallery
How is the thermostat sensor related to performance or gas mileage?
I saw this in the web : http://auto.howstuffworks.com/framed...ewtrouble.html
11) Wrong or malfunctioning thermostat in cooling system.
Can anybody further explain this?
aldwinenriquez is offline   Reply With Quote
Old 05-23-2007, 11:54 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
hmmm im gonna gues that unless the engine is at its peak temp, or colder in this case it takes more gas to keep it running, like when u start the motor cold it revs up till its ward, and if the thermostat is out it would not let it get up to temp and therefore use more gas
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 05-24-2007, 12:21 AM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
2 fold problem
1. takes longer to heat up so it runs in warmup mode longer
2. during normal driving the engine can dip to the warmup temp threshold and run poorly
warmup mode burns more gas and runs sluggish because of several things, the trans shifts differently and some sensor inputs are ignored.
Old 05-24-2007, 12:35 AM   #4 (permalink)
View toyomoho's Photo Gallery
Operating at engine temps lower then designed for results in increased engine wear, higher fuel comsumption and lower HP output.
Old 05-24-2007, 11:26 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
I'll be replacing my thermostat after reading this thread.. it makes sense when I think about how my car stays in warmup mode even when it's not cold outside. Thermostats are cheap so I'll give that a shot.
Old 05-24-2007, 07:10 PM   #6 (permalink)
View Got50Fever's Photo Gallery
And if you fail smog on your HCs (if you have to pass smog) t-stat is a good place to start looking for the problem
College student and U.S. Marine. The possibilities are endless!
Got50Fever is offline   Reply With Quote
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 01:06 PM
Please do not use U-Haul... bad experience (long post) rayray Off Topic 15 03-05-2008 08:20 PM
Bad O2 Sensor: Bank 1 Sensor 1 HELP!!!!! pjwr2004 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-13-2006 08:18 PM
gas milage and O2 sensor jdwilson 89-95 Toyota Pickup/Hilux 6 06-06-2006 04:29 PM
