speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2007, 04:31 PM   #1 (permalink)
View toyota_b's Photo Gallery
speakers
I an putting in a new set of speakers in my car and took the door panel off but the speakers are what seems to be glued into a peice of plastic that is rivited in. I am trying to put my new speakers and in and i can not figured out a way for the stocks to stay togethor and just take them out, and still be able to put my new speakers in because the new ones are a screw type of speaker. This is in a 2003 toyota carolla.
toyota_b is offline   Reply With Quote
Old 05-24-2007, 08:14 PM   #2 (permalink)
View sponger's Photo Gallery
Let me see if I understand your situation right.
The stock speakers are glued into place, and so you're trying to remove them without tearing them apart?
You're concerned that after you remove them, you'll have difficulty getting the after-market speakers into the brackets because those speakers are designed to be screwed in instead of glued in?
sponger is offline   Reply With Quote
Old 05-24-2007, 08:25 PM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
In my 01 corolla, My stock speakers were glued to the metal. I took it to best buy and helped them instal it. You break the glue, and screw the new speakers in.
The only problem with this, Is that we Have different generation rollas, so It might be different.
Crowbar911 is offline   Reply With Quote
Old 05-24-2007, 11:16 PM   #4 (permalink)
they are in a peice of plastic that is rivited in. I bought a indash kit from crutchfeild and they gave me some directions im am supposed to drill the rivits out then get an ada[ter plate from what i read on the directions... I wish i could just put them in i thought it was going to be a 5 mins job now i have to order some more crap. I guess i would get the adapter plates from ebay or somthing??? I know i have to go by the speaker size however am i supposed to get some with an ear or two so that i can drill through the sheet metal and bolt the plate down then the speaker?
thanks,
B
Old 05-25-2007, 11:08 AM   #5 (permalink)
View dgoodhue's Photo Gallery
Mine stock fronts speaker were riveted in. All my stock speaker require adapters to make any aftermarket speaker fit, so much for bolting it the coxials I had laying around
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Installing speakers - '91 Corolla Dirtjump9 Audio, Video, and Security - Tech 2 06-25-2006 11:18 AM
Looking to replace factory speakers, need suggestions t^3 Audio, Video, and Security - Tech 7 03-29-2006 04:14 PM
04 Tacoma DBL Cab Speakers Loop 1st Generation (1995.5–2004) 5 01-08-2006 04:47 AM
attn: Xenon - or anyone whos done speakers on a 98 corolla fatredcircle Audio, Video, and Security - Tech 2 11-04-2002 07:40 PM
