Oil leaks - thoughts? (with pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2007, 12:12 AM   #1 (permalink)
noob
View poiter_mcd's Photo Gallery
Australia Oil leaks - thoughts? (with pics)
Hi all,
2 separate leaks on my 97 Corolla.
ONE: I think is my stupidity for not keeping a closer 'containment' of oil when I change the filter (which would explain it being dirtry down bottom, but clean on top part of sump), but I just want to see what people think, and;
TWO: on the transmission.
Any thoughts from anyone????
Thanks heaps. Great forum, helpful people, great backlog of posts.
ONE (btw, noob question: what is that hose coming out of the sump????)
TWO
poiter_mcd is offline   Reply With Quote
Old 05-27-2007, 03:58 AM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Question
Tranny leak: check your flange seals, your half-axle seals, where the axle goes into the tranny. is that an auto or manual trans, what kkind of oil is the leaky stuff? Look up, from underneath with car on jacks, and look at the seals,, are they wet with oil?
Engine oil on oil pan: can be valve cover oil, or accumulation from doing sloppy oil changes. Only way to tell is to clean the engine very good, and watch where it comes from, it's to hard to find leaks when oil is everywhere. if/when you clean engine, cover electronics. Pick your method of cleaning. Of you use high pressure water, be very careful where you point it. (sorry, thought I would point that out).
retiredat44 is offline   Reply With Quote
Old 05-27-2007, 04:27 AM   #3 (permalink)
noob
Australia
It's a manual. Was planning on cleaning it all off, and keeping an eye on it, but wanted to get some pics first 'for history sake'.
Not sure on the type of oil it is - I'm not brilliant at determining the type, but will give it a try.
Will put car up again and have a squizz at all the seals.
Thanks. No need to be sorry - I've started to clean out the engine this weekend, and it's a right royal pain in the a**e - 205,000kms worth of crap on it. I don't want to go the option of covering and doing a big spray as, knowing me, i'll miss something, and bugger something up. So, i'm going slowly but 'softly' as it were.
thanks again for the response - will have more of a poke around when I get a chance.
cya
Poiter
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Another oil change horror story! witxp 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-13-2007 12:29 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
changed oil, now my car leaks oil mofojordan Camry & Solara Lounge 3 11-29-2003 10:49 PM
