Water pump replacement extravaganza - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2007, 12:28 PM   #1 (permalink)
View pdeboer's Photo Gallery
Hi, I'm pretty new here. I am replacing the water pump on a friends 94 corolla. I am having a heck of a time figuring out how to get the timing chain cover off. The waterpump pulley prevents the plastic from coming out, but there really isn't enough room to pull the pulley. I'm used to working on german cars and diesels, so I was a little embarrased after I told my friend it was a 40 minute job, we are on hour 7 or so. Anyone have experience with this?
pdeboer is offline   Reply With Quote
Old 05-27-2007, 12:48 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
94's are a timing belt, and from what i can see the timing belt cover doesnt cover the water pump.
which engine is this? 4afe or 7afe?
Old 05-27-2007, 02:17 PM   #3 (permalink)
View tech8's Photo Gallery
The 94 Corolla has a timing belt. The timing belt cover is 3 parts. Unless you were changing the timing belt, I don't believe you need to remove all the covers. You only need to remove the crankshaft pulley to remove the lower timing belt cover, if you were replacing the timing belt.
Remove the upper timing belt covers, and you should be able to access the water pump.
tech8 is offline   Reply With Quote
Old 05-27-2007, 02:22 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
Yes the water pump pulley has to come off to get the middle timing cover off... the way i get the pulley off is with a 10mm wrench from the underside of the car by holding the pulley with a oil filter wrench, or a strap wrench or last resort using the belt around the pulley and holding it or by loosening the bolts right off first thing while the belts are still on everything.
its a bitch the water pump has to be the 2end biggest PITA on a gen 7, first being the rear engine mount...
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 05-27-2007, 04:25 PM   #5 (permalink)
Found this guide with illustrations:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 05-27-2007, 10:35 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
that's why it's a good time to replace the timing belt and bearing along with the water pump, since you have it aparts anyways...
retiredat44 is offline   Reply With Quote
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
98' Camry Water Pump repair cost? mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2008 06:11 PM
Help!! Water pump or oil pump is going bad?? fincoon 3rd & 4th Generation (1992–1996 & 1997–2001) 11 01-17-2008 11:37 AM
02 Camry Water Pump Replacement rkelachim 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 02:08 AM
96 1MZ-FE Water Pump Replacement Question? V6LE_CAMRY 3rd & 4th Generation (1992–1996 & 1997–2001) 10 07-28-2005 07:53 PM
