Thanks to everyone who replied. Unfortunately the head of the bolt is (Or was !) 24mm, and there are not many bolt extractors that size. I have tried all of my tools to lock onto it, but there is just not enough room for the tool to completly grab around the bolt head.
I did manage to drain the fluid...only about 3/4 of a litre came out, and tightened the drain plug back on. I did find a hole where the gear shift enters the tranny, and carefully pushed a wire in to see if it goes all the way into the tranny, and it did. So I placed a long thin tube on the end of the gear oil bottle, and let it slowly flow into it. I will remove the drain hole tonight and see if clean tranny fluid comes out..........Anyone done this before? There's a lot of praying and finger-crossing in my garage at the moment.....
Thanks again
Eugene
