97 4afe cooling issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2007, 07:36 PM   #1 (permalink)
View canadiancelica's Photo Gallery
So over the weekend I flushed the cooling system & put in a new thermostat. Can't get the coolant to circulate. The t-stat is opening as I had hot water running into the engine and it came back out the other end. But i cant seem to get the inlet hose to warm up/take water into the engine. Any ideas or tips or tricks. Garage is last ditch effort. lol
thanx all
canadiancelica is offline   Reply With Quote
Old 05-29-2007, 08:18 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
is the hose going to the bottom of the rad getting hot? is the radiator full of fluid? is the bleed valve in the new tstat at the 12 o clock position?
Old 05-30-2007, 10:49 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Inlet hose warms up when the thermostat opens. Might be around 82c so the hoses do get quite warm.
Old 05-30-2007, 03:14 PM   #4 (permalink)
Turns out it was the thermostat that toyota sold me was the wrong one. It was a little larger in diameter then the one I took out so it wasnt sealing properly and sucking in air. I, of course, tried to tighten the nuts & broke them off. now Im even more fugged
Old 06-01-2007, 06:09 PM   #5 (permalink)
Hose stays cold
rad is full
yes on the bleed on the t-stat
Nothing has worked. I've tried everything.
That lower hose just doesn't get hot and the radiator gets super hot as does everything else. Only thing I can think of now are:
1) New thermostat is a dud
2) Some kind of crazy air lock in inlet hose.
Going to try to use the rad fan sensor as a bleed screw tomorrow to try and get coolant up in that hose. If that doesn't work it's going to toyota monday morning and will sit there until they have time to look at it.
Old 06-01-2007, 08:00 PM   #6 (permalink)
Bitter's Avatar
when i did mine, it took a good 20 minutes to bleed just the air from changing the tstat! had to wait for the engine to heat up then the tstat to completely open. the rad did get warm, i saw the fluid flowing past the cap opening, a few bubbles, but not much ya know. then finall blurp blurp bubble bubble! i revved the engine up and down a little while doing this to gett he fluid really moving.
Old 06-02-2007, 06:34 AM   #7 (permalink)
It's run a good half hour and GOTTEN HOT. Few small bubbles, I've even driven it around, but that lower hose doesn't get warm. I know the water pump works cause i can get coolant to flood out when revving.
Gonna try to bleed that lower hose today, if not, I can only assume the new t-stat I got from toyota is bunk
John
Old 06-02-2007, 07:31 AM   #8 (permalink)
Bitter's Avatar
that is possible, are you 100% sure they gave you the correct part? guy on another corolla board or maybe it was a celica site had gotten the wrong part, the tstat was too large and was not able to open fully.
Old 06-02-2007, 03:30 PM   #9 (permalink)
hmmmmm, I'll have to check that out monday. I can manually put coolant through the engine when the t-stat is open. pour it in the upper hose and it raises the level in the rad & over flows it. I got some bubbles out, but after about 40 minutes of idling the rad began to boil (small rapid bubbles).... I can't figure this one out atall.
Did the 97 corolla come stock with an aluminum radiator??
I put an aftermarket aluminum rad in my celica and had trouble with the OEM rad cap sealing properly. I'm wondering if the previous owner replaced it and didnt mention it.
Old 06-02-2007, 05:17 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
yes they had aluminium radiators with plastic tanks.
Old 06-02-2007, 09:35 PM   #11 (permalink)
thanx, that rules out that possible issue
Old 06-02-2007, 09:39 PM   #12 (permalink)
Bitter's Avatar
if its getting hot enough to boil the radiator fluid then the fans would be cycling on, even with the cap off. the coolant is moving around in the rad when you rev the engine and the level rises and falls, whats the temp needle doing?
Old 06-03-2007, 07:13 AM   #13 (permalink)
Sitting @ 1/2 way mark the entire time. Rad did begin to boil, rad fan did NOT turn on. I discovered I have to unplug that to turn it on, so that sensor is toast.
Water pump definitely causes turbulence in the fluid.
When I allowed the rad to come to a near boil, the lower hose was hot, but it seemed like it was from conduction, it wasn't nearly as hot as the water in the rad, and as soon as I turned the fan on it or went for a drive, the lower hose went ICE cold. The system is only building minimal pressure as well, I can still squeeze the hose to touch even after a good 20 minutes, 120kph highway run.
Old 06-03-2007, 07:46 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
I'm thinking maybe you dont have a problem, but your analysis methods are wrong...
Old 06-03-2007, 10:04 AM   #15 (permalink)
You could be correct!!
I'm just going to drive it and if it pops, then it pops, if not, then sweet. 4afe heads are easy to come by locally, lots of corollas kickin around. I'm out of patience and caring. It's only a 18/20 month fill in since dominoz wrote my other car off
thanx all. I'll let ya know if/when it blows up. lol
4afe to 7afe ranterc Archived Corolla threads 4 03-06-2007 01:14 PM
1994 Camry stalling issue y2k2s2k 3rd & 4th Generation (1992–1996 & 1997–2001) 6 11-14-2006 02:27 AM
Seat Belt issue on Corolla 97 anorbert Archived Corolla threads 2 10-11-2006 03:36 PM
2006 RAV4 performance issue mranu RAV4 Forum 0 09-06-2006 11:21 AM
What is the HP difference of a Early 4AFE and a Late 4AFE? toyloco Archived Corolla threads 10 08-05-2006 07:54 AM
