the second O2 sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2007, 11:50 AM   #1 (permalink)
View Gman94's Photo Gallery
I have a 95 prizm/corolla it has 2 O2 sensors one on the header and one after the cat but I dont have an OBD2 plug cause I guess this is the year before they put in the plug, but I was just wondering if I really need it cause im going to be replacing the stock exhaust from the downpipe all the way back and need to know if I have to custom fit that in or if I can just unplug it and run off the one at the header?
http://www.cardomain.com/ride/2484831
1995 geo prizm: header, hi flow cat, full stainless steel catback exhaust, Short ram intake, custom functional hood, body kit and converted to manual.
Gman94 is offline   Reply With Quote
Old 05-30-2007, 01:21 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
yes you need it, i suspect that you might have a cali spec corolla. there were 3 iterations of 7th gen.
fed spec
cali spec
obd2 cali spec
fed spec has one sensor in the exhaust manifold and a cat
cali spec has 2, one in the manifold and one after the cat and i tihnk has 2 cats (one attached to the manifold, its a big bulge)
obd2 has 3 sensors i think, one before the precat, one after the precat and one after the main cat. i know less about the cali spec and the obd2 since mine is a 93 fedspec. iirc the cali and obd2 also have EGR and do not have adjustable timing.
as for the exhaust, just get a bung welded in and put that sensor in. a bung shouldnt cost more than $50 to get it installed by a shop. if you're decatting then you'll need to use the antifouler trick which can be readily found on google.
Old 05-30-2007, 03:37 PM   #3 (permalink)
I just have one cat and i didnt have that manifold with the big bulge on it it was a regular manifold until i changed it to headers.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
