when you say parking light it's the amber on the corner of the front bumper correct? If so there's a screw that holds it in and all you have to do is unscrew that out and carefully pull it out and it will expose the bulb. You can pull it out quite easily by turning it(i think counter clock wise) then out. You can get the bulb out and purchase the new ones. I had problems with mine because the screws were all weathered and stripped, so i just went under the car, reached for the bulb, turned it and pulled it out and switched it that way
