replace 2001 struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2007, 10:24 AM   #1 (permalink)
View pitbull30's Photo Gallery
How hard is it to replace the front struts on a 01 corolla myself. I searched for some articles online but couldnt come up with much.
Also what type do you recommend. I dont need anything fancy but would like a smooth ride.
Figured some of you here have some good knowledge on this.
Thanks
pitbull30 is offline   Reply With Quote
Old 06-01-2007, 02:38 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Thanks
This is for a 99:
http://www.toyotanation.com/forum/t171852.html
Should be the same for your 01.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-01-2007, 04:45 PM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Every toyota front MacPherson setup I have ever worked on has been the same. The only difference you'll have is where the sway bar connects.
You'll need to rent a spring compressor.
Then there's...
Three nuts on the strut mount under the hood.
Two bolts at the knuckle
One nut at the sway bar
One bolt on the brake line
One nut at the end of the piston shaft.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Possible to replace struts without removing wheel? jtu100 1st & 2nd Generation (1983–1986 & 1987-1991) 12 04-25-2007 07:29 PM
Fairly Comprehensive factory 0-60 times under 6 sec. Rdizzle General Discussion 15 04-09-2007 10:12 PM
Replacement struts question toytrain13 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-30-2006 08:39 PM
91 Camry struts EYE_AM_CRAZY 1st & 2nd Generation (1983–1986 & 1987-1991) 4 11-14-2003 12:08 AM
