steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2007, 11:25 AM   #1 (permalink)
View igorien2k's Photo Gallery
steering
so there is something wrong with my steering rack. when i turn the wheel back and forth there is a distinct click from the rack when i change the wheel direction and both of the wheels are loose when i move them with my hands in the horizontal direction. the tie-rods look fine. do i simply need a new rack? or is there another way to fix the problem
igorien2k is offline   Reply With Quote
Old 06-01-2007, 01:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
When you move the tire in the horizontal direction by hand does the steering wheel move in proportion to the tire movement? Do both tires have the same amount of free play? The rack has a universal joint on each side of it. This joint/rod attaches to the tie rod end. You can see them by removing the rack boots. Check these joints for play.
Steering knuckle and hub assembly abew330 Camry & Solara Lounge 0 02-07-2007 06:02 PM
Steering troubles... grndslm Archived Corolla threads 5 10-31-2006 12:05 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
Power Steering Checklist help blazin_azn MR2 Forum 14 06-13-2005 09:31 AM
No horn / steering wheel basic electrical stilllearning6 Celica Forum 1 03-17-2005 07:38 AM
