Raise (?) suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2007, 12:00 PM   #1 (permalink)
tylan71's Avatar
View tylan71's Photo Gallery
94 Corolla 1.6L, Just put new tires on and when I round corners, a hear rubbing. I am about ready to put new struts on all the way around. After 88000 miles will the new struts lift the car up a bit to stop the rubbing? I think it is rubbing the part of the rear strut that the spring sets in. I am putting in KYB GR2 struts.
tylan71 is offline   Reply With Quote
Old 06-02-2007, 01:14 PM   #2 (permalink)
BANNED
View w203's Photo Gallery
What? I'm not following. You running on stock suspension and experience rubbing and want to raise it or do you already have aftermarket suspension? What are the tire size? Are they stock sizing? Be specific...
w203 is offline   Reply With Quote
Old 06-02-2007, 01:27 PM   #3 (permalink)
tylan71's Avatar
Sorry. Yes, stock suspension. Tires are 185/70/14. I replaced the tires with the same size tires but different brand ( I put on GY Assurance tripletreds) and I think that, even though the same size specification wise, they are slightly wider, maybe taller, not sure. I guess my question is, does the stock suspension settle and lower somewhat over time and will the installation of new struts raise the car a little (back to original height) and eliminate the rubbing?
Old 06-02-2007, 01:43 PM   #4 (permalink)
BANNED
Hm....I've checked and your stock tire sizing should be 185/65/14. Correct me if I (tirerack) am wrong.
Old 06-02-2007, 01:48 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
if they rub on the spring plate, lifting the car wont help.
Old 06-02-2007, 01:56 PM   #6 (permalink)
tylan71's Avatar
I guess the 70 aspect tires are too big. The tires that were on there were 185/70/14 size and there was no rubbing with them. The rubbing only happens when I turn so would stiffer struts help eliminate the rubbing?
Old 06-02-2007, 03:26 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Well no, not if they rub on the fenderwells. Correcting this with stiffer struts is fixing a problem with another problem.
Suspension system - Need Help/Advice! bavula 3rd & 4th Generation (1992–1996 & 1997–2001) 15 04-18-2007 11:04 PM
2' suspension lift rollem 89-95 Toyota Pickup/Hilux 5 07-15-2006 08:13 PM
New Suspension Parts? anyone? Toyn671 89-95 Toyota Pickup/Hilux 4 06-09-2006 09:17 AM
Suspension setup for comfort doru Camry & Solara Lounge 12 04-05-2005 12:52 PM
