restrictive intake manifold(pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2007, 02:23 PM   #1 (permalink)
View Beemik's Photo Gallery
Here are some picture of inside the intake manifold of the 4/7afe. This thing was desinged with one purpose; to restrict the air flow to the engine
And they sure did a good job. I think I'll be making some changes.
Beemik is offline   Reply With Quote
Old 06-02-2007, 03:27 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Those runners look actually pretty good. I doubt they'd restrict _that_ much. Besides your head is a worse restriction.
Old 06-02-2007, 05:39 PM   #3 (permalink)
Ya the runners do look pretty good. You can't see it that well in this picture but the line across the bottom of the runners is about an 1.5 inches high with those two boars being a seperate cavity
Old 06-02-2007, 05:40 PM   #4 (permalink)
Sorry I meant in the pervious picture.
Old 06-02-2007, 05:41 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Thats not going to act as a restrictor... just FYI.
Old 06-02-2007, 06:32 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
doesnt look that bad, i've been wondering what it looks like in there. iirc that chamber is to control sound.
Old 06-02-2007, 06:55 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
and to control air dispersion... anyways plenuum volume is more important and the shape.
Old 06-02-2007, 07:10 PM   #8 (permalink)
Bitter's Avatar
i've seen worse stock manifolds, ever seen those of the 2000-2005 2.4L 4G64 in the Eclipse? NO plenum! just runners and a throttle body.
Old 06-02-2007, 09:46 PM   #9 (permalink)
i was thinking something like this.
Also like you said Flashmn about volume i was thinking about milling a 10mm spacer to put between the upper and lower. Very rough measurments; about an extra 200cc in the chamber. Any thoughts?
Old 06-02-2007, 10:07 PM   #10 (permalink)
Chitty Chitty Vroom Vroom
View Criard's Photo Gallery
I know nothing about the inner workings of intake manifolds. but I can kinda see how it works, and I see what you're trying to do. my only thoughts are.... 'intriguing'
I would probably think the same thing as you, and contemplate doing the same thing. Good luck if you decide to go through with it!
Criard is offline   Reply With Quote
Old 06-02-2007, 10:16 PM   #11 (permalink)
Bitter's Avatar
let us know how it goes and be sure to keep us updated. if theres good gains i'll get a spare from the junkyard on the 1/2 price day and try it too.
why not remove the whole wall and then make the knotches?
Old 06-02-2007, 10:26 PM   #12 (permalink)
There doesn't seem to be enough room because of the way the runners curl under. i got this one from the scrap yard for only $20. I also picked up a throttle body that I wanted to boar but the 56mm wont happen. I might be luckey to boar it to 52-53mm, there just isn't enough material. the manifold also came with the fuel rail which I'll paint a really pretty colour
Old 06-02-2007, 11:44 PM   #13 (permalink)
Bitter's Avatar
i see what you mean about the curling, i'm pretty interested to know how this works out since i like cheap/free mods. i can understand your reasoning behind this, its tricky tho how it could effect the engine.
Old 06-02-2007, 11:59 PM   #14 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Intake castings are left rough because it creates turbulence to help mix the air and fuel better. And, yes, also because it would cost too much for the castings to be machined.
FYI
retiredat44 is offline   Reply With Quote
Old 06-03-2007, 01:20 AM   #15 (permalink)
The casting of the runners is pretty good! I'll post a close up later. A minor polish wont do too much. Even the ports line up pretty good. And FYI. It's the cost. The castings are rough because of the sand that is used to make the cast piece. Some manufactures use a more coarse sand then others leaving a rougher finish.
The creation of turbulence is required at the piont of injection and below. Runners also become smaller at this stage to increace velocity and reduce wall spray.
HELP! Performance upgrade for a v6... afnan_jamil 3rd & 4th Generation (1992–1996 & 1997–2001) 61 10-08-2006 05:25 PM
New Idea For Intake (new to me at least lol) fistofmeat Archived Corolla threads 6 09-13-2006 05:20 PM
Air Temp. tube questions (Intake Install) Mousiee Camry & Solara Lounge 1 04-13-2006 05:17 PM
1996 Camry Intake Question Sniperdude 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-23-2006 06:59 PM
