Removing spark plug lead at dist cap end...???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2007, 09:29 PM   #1 (permalink)
noob
View poiter_mcd's Photo Gallery
Australia Removing spark plug lead at dist cap end...????
Hi all,
Just going to check resistance in spark plug leads on 97 Corolla (1.8) and can't for the life of me figure out how to remove the lead at the dist cap. Pic of connection below.
I never 'force' things as I usually break them, but is there a trick for this connection???
thanks heaps.
Poiter
poiter_mcd is offline   Reply With Quote
Old 06-03-2007, 09:32 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
hmm iirc in the US 96 and higher are not removeable. otherwise theres a clip that you have to lift a little to get the wire retainer off. a small flatblade will lift it, then just pull.
Old 06-03-2007, 10:13 PM   #3 (permalink)
noob
thanks for the response.
Wow - not removable - does that mean they sell the dist cap & leads as 1 spare part??
There's no metal clip to lift, and I've just had my next door neighbour (who is one of those old guys who knows everything about everything) to have a look and he couldn't figure it out either...
weird...
Old 06-03-2007, 10:24 PM   #4 (permalink)
View toyota_b's Photo Gallery
I havent checked mine yet but i hope the newer models are not like that
toyota_b is offline   Reply With Quote
Old 06-03-2007, 10:40 PM   #5 (permalink)
noob
Australia
Just rang up Toyota, and they said they definitely DO come off ($177 AUS for a new set of leads, $132 for new cap; separate parts).
Strange - will keep trying...anyone else managed to get them off???
Old 06-03-2007, 11:14 PM   #6 (permalink)
Bitter's Avatar
the clip isnt metal, its plastic and part of the retainer. i just cant think of how it goes off the top of my head! its across from the rectangular shaped thing on the side of the retainer, thats actually an alignment tab.
Old 06-04-2007, 01:12 AM   #7 (permalink)
noob
Australia
Sussed it. thanks for the help.
Get a small flat blade screwdriver and lift the what I would call 'retaining clip' (on the opposite (other) side of the plastic retainer in the picture above). When you lift, the retainer will slide away from the plug end. Enjoy!
thanks again for the help everyone.
cya
Poiter
Old 06-04-2007, 06:56 PM   #8 (permalink)
Bitter's Avatar
yep! thats exactly it bud. i'm glad what i tried to describe helped you out and that you got them off.
Old 06-05-2007, 01:06 AM   #9 (permalink)
noob
yeah, thanks heaps bitter. was a big help. weird design, but hey, better than having to replace both in one.
Old 06-05-2007, 11:46 AM   #10 (permalink)
Bitter's Avatar
yes, in the US the odb2 or the cali spec 7th gen corollla has the wires glued to the cap for some reason, i guess they figured that by the time either part was worn the other part would be worn out as well.
Need help with spark plug diagnosis alkon Camry & Solara Lounge 3 12-01-2005 08:13 PM
gen2 91 camry damaged spark plug wires desertstrm2000 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-02-2005 02:42 PM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
Spark plug wire boot ']['R][) camry Camry & Solara Lounge 10 04-18-2004 12:59 AM
removing spark plug wires Zich Camry & Solara Lounge 1 05-30-2003 11:39 PM
