Temperature and Fuel Gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2007, 05:07 PM   #1 (permalink)
View theredsuit's Photo Gallery
AE92 Temperature and Fuel Gauge
Hello,
My girlfriend has a 1992 corolla 4 door but I can't remeber what the trim is. Anyway a while back her temperature gauge and fuel gauge quit working. Now they both go right to the top of their respective gauges. The only way she can tell when she needs fuel is when the light comes on or she's been watching her milage on the tripometer. When the car is turned off the needles both go back to the bottom of their gauges so they're not stuck as some might mention. I've read on this forum that the cluster may have to be replaced, I'd like to know if there is some tests I can perform to see before I go that route.
Also her cruise contro does not work anymore either. I'm going to check with her manual to fix it and see if there's a wire connection issue. Does anyone know of some common issues with the cruise control on these cars.
Thanks
theredsuit is offline   Reply With Quote
Old 06-04-2007, 05:12 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
probably a grounding problem
Old 06-05-2007, 11:10 AM   #3 (permalink)
Would this be a main grounding wire or part of the wireing harness to the cluster set?
Old 06-05-2007, 05:41 PM   #4 (permalink)
View aarong420's Photo Gallery
^^^ grounding for the instrument cluster..
check your fuses too...
do you have a diagram for the stock instrument panel?
aarong420 is offline   Reply With Quote
Old 06-06-2007, 03:28 PM   #5 (permalink)
http://www.autolib.diakom.ru/CAR/Toyota/
if you pull down 1991 Corolla wiring diagram and pull figures 12 and 13 those are what i have for diagrams.
A nice fellow on this forum sent me the links. If you have an easier diagram to follow that would be cool! I'm no electrician so I'm not sure where to start.
BTW, all the fuses are okay. I pulled each one and inspected them. No problem there.
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
