Head shaving help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2007, 08:38 AM   #1 (permalink)
View circusracer's Photo Gallery
Head shaving help
Hey guys, I have an '89 corolla with the 4A carb motor, I am taking off the head and having it milled down to bump the compression ratio for some more power. My question is: what is the most I can take off the head safely before I have to worry about wacking a pistion? Thank you for any advice.
circusracer is offline   Reply With Quote
Old 06-05-2007, 02:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
You can use clay to determine the exact clearances you have now. 0.040 is stated to be OK for most engines. A lot things effect compressing including having a valve job, which sinks them lower in the head and increases chamber volume.
A better way to go might be looking for a thinner gasket at performance websites. This will extend you heads life in case one day you remove it, find it is warped and it needs to be faced off again. Milling the head will increase compression but not that much.
Old 06-06-2007, 01:42 AM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
if you want a thinner gasket look at a 1993-1997 7A-FE head gasket there multi-layer steel and its like .023" thick i think it should work on the 4A-F compare the two.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Having head problems w/ a 22RE sidingmonkey 89-95 Toyota Pickup/Hilux 22 04-05-2007 03:28 PM
Corolla/Prism Head Gasket wheredoesthisgo Archived Corolla threads 3 03-24-2007 10:39 AM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
Coolant Consumption After Head Gasket Replacement. Bullz_EyE Pre-88 Toyota Pickup/Hilux 4 05-06-2006 08:23 AM
