Broken Exhaust Manifold Stud - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2007, 10:59 PM   #1 (permalink)
View stratofactor's Photo Gallery
My dad has a 95 Corolla, 1.6 and I broke off one of the studs that holds the exhaust pipe to the exhaust manifold. There is about 3/8 of a inch of the stud sticking out of the exhaust manifold. Can I weld a nut to the stud and then un-screw the stud out of the manifold and replace it with a new one or will I have to drill it out.
Thanks
stratofactor is offline   Reply With Quote
Old 06-10-2007, 11:00 AM   #2 (permalink)
View JustinGB's Photo Gallery
I have a similar problem and I was wondering if I should just knock the bolt out by breaking it and if so what techniques to break it out. Specifically the ones holding the cat.
JustinGB is offline   Reply With Quote
Old 06-10-2007, 12:02 PM   #3 (permalink)
View OEMonkey's Photo Gallery
welding a nut on there will work. Or just use a stud remover socket. You have to use the correct size stud remover socket (I think 10mm in your case), and soak the stud w/ pb blaster to penetrate the rust and loosen it up if it's seized. If you have to drill it out, don't worry too much about damaging the threads. You can always just use a nut and bolt through it instead of the stock stud/nut.
OEMonkey is offline   Reply With Quote
Old 06-10-2007, 12:03 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
theres a tool that grips the stud and turns it out. Try asking the local tool shop for one of them
Old 06-10-2007, 01:09 PM   #5 (permalink)
View Tavel's Photo Gallery
hahaha, how come I don't think of things like that. I crossed the threads and spent 2 hours filing the bolt and massaging it back into the hole.
I should have drilled it out and gotten a new lag bolt at the hardware store!
Tavel is offline   Reply With Quote
st185 exhaust manifold 89SV21 Celica Forum 4 07-04-2006 01:38 PM
22re exhaust manifold gerhardf 89-95 Toyota Pickup/Hilux 2 03-19-2006 06:16 PM
Exhaust Manifold Chillin Chik Tercel, Paseo, Starlet, and Sera Forum 30 09-27-2005 10:45 PM
rattle/buzz@2300 = cracked exhaust manifold? dsap100 Celica Forum 2 09-14-2005 12:21 PM
