Flywheel bolts questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2007, 11:43 PM   #1 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Car is a ZZE110 with a 1ZZ motor.
Can the flywheel bolts be reused when changing flywheels? And for doing auto/manual conversion, when the flex plate is removed and flywheel installed, can the bolts tha come off when the flex plate be reused when installing flywheel? IOW are there any difference between the flywheel bolts used for auto and manual trannies?
Reason is the repair manual specifies different torque for auto and manual flywheels, and monkeywrenchracing says the flywheel bolts are not reusable.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-10-2007, 12:34 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Yes, there will be.
The bolts are re-useable I've reused the bolts on everyflywheel i've ever taken off, and never had a problem.
But the flywheel (manual) bolts have a bigger shoulder on them, to allow for the extra thickness of the flywheel.
They are also usually longer.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Engine questions.....5sfe, 3sge, 3sgte mynameizblank MR2 Forum 10 07-26-2008 01:19 PM
Clutch? Flywheel? spikesc Pre-88 Toyota Pickup/Hilux 1 04-04-2007 01:27 AM
freeing rusted exhaust bolts 400exboy2 3rd & 4th Generation (1992–1996 & 1997–2001) 6 03-28-2007 10:22 PM
Bolts break on 93 Toy 4x4 Pickup V6 PurplePower 89-95 Toyota Pickup/Hilux 3 03-12-2007 07:03 AM
Looking for rod bolts undertow29 89-95 Toyota Pickup/Hilux 20 02-13-2007 05:11 AM
