My 2001 corolla (1zz-fe) take 3.9 quarts of oil when you change your filter. I always change my filter, So i don't know how much it is without changing it.
As for the tranny fluid, You fill up until it shows its enough on the dipstick. this can take a while, so be carful. When I changed My tranny fluid(also changed the fliter), I think I put around 3.5 - 4 quarts in.
For the tranny, you put the fluid into where the dipstick is, so its hard to get a good reading if you don't let it sit for a while. just take your time.
(my tranny is a 3 speed with overdrive, if you have a different one, it will take a different amount)
I have a question, If I put in 4 quarts instead of 3.9, will that be ok? I can' imagine that a extra .1 quart of oil would hurt.
