trouble codes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2007, 06:57 PM   #1 (permalink)
View whatproblems's Photo Gallery
trouble codes?
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
brought car to a friends house and he plugged it in and got the codes for me
what the hell do these mean?
and P0440 and 0446 showed up twice
whatproblems is offline   Reply With Quote
Old 06-11-2007, 07:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
The codes are 0440, 0441 and 0446. Start out checking the 0441 and 0446 codes. The 0440 is a general code.
What year and model car is this? Toyota has an extended warranty on some vehicles per EPA lawsuit.
The fuel tank is sealed to prevent gasoline emissions. The charcoal canister absorbs any gas fumes and stores them. The fumes are then directed to the engine to be burned when running.
The system has a pressure sensor to detect if the tank remains pressured. If the tank depressurizes or fails to pressurize (after gas tank fillup), codes are tripped indicating an air leak someone or one of the system components is not working.
Problem areas with these codes: Vacuum hose leaks in fuel tank in emissions control system. Check hoses to the charcoal canister and VSV systems. Canister could have leak, defective VSV for pressure sensor or EVAP, vapor pressure sensor, fuel tank overfull check valve. Also check the gas cap seal.
Check the seal on the gas cap first, then for broken, plugged or damaged hoses in the emission control system.
Old 06-11-2007, 07:56 PM   #3 (permalink)
car is a 2001 chevy prizm, which is basically the same thing as an 01 corolla
any help is greatly appreciated,
i'm looking into the gas thing tomorrow
Old 06-11-2007, 10:05 PM   #4 (permalink)
Check out this post:
http://www.obd-codes.com/forums/570-...440-p0441.html
Have CEL, how do i get the trouble codes dangger RAV4 Forum 1 10-24-2006 07:40 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Transmission Trouble Codes camryfour Camry & Solara Lounge 3 06-23-2006 11:16 PM
Help! 2000 Sienna Trouble Codes vadad23 1st Generation (1998-2003) 0 12-09-2005 02:09 PM
