93 7A-FE ignition problem
Hi guys,
My first post, so be kind! I've got a 93 7A-FE corolla that will once in a while have the engine rpms bobble, followed by a stall. It is then really hard to get it started again (5-6 tries), but eventually it will start and run completely normally.
I've checked the following:
-battery terminal connections
-spark plug wires on snugly
-distributer cap seems intact and on securely
-no wires seem to be disconnected
This problem happens very rarely (maybe once every two months), so its not a huge deal, however I don't want to get stuck on a busy road where I can't pull over next time.
Any suggestions on things to check? Is it worth replacing the sitributer, spark plugs, just to rule those out?
Thanks!
