98 Squeaky Breaks? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2007, 05:30 PM   #1 (permalink)
View devham's Photo Gallery
Unhappy 98 Squeaky Breaks?
ok so my car just strarted to squeak... like super badly one day. I had it checked over and the garage said that its really nothing its cause of what my breaks are made out of. The mechanic said that its cause when its humid. Well lately its been getting worse and i feel that my breaks dont work as good.
My question is... is the garage trustworthy or should i get some new breaks.
Second question is... what kind of breaks and from where.
Ps. The mechanic said that there is some surface rust on it... would that have anything to do with it?
devham is offline   Reply With Quote
Old 06-15-2007, 11:12 PM   #2 (permalink)
BANNED
View w203's Photo Gallery
Surface rust should be gone once the your use your brakes and the pad touches them. You might see rust form on places elsewhere, nothing to be concerned about. Take a pic of your pad as well as the rotors since its hard to diagnose over the internet with words. As squeeking can be lots of things from the vibration of the pad's backing to the pads telling you you need new brakes and to the materials of the pads used.
w203 is offline   Reply With Quote
Old 06-15-2007, 11:29 PM   #3 (permalink)
View toyomoho's Photo Gallery
Front or rear brakes? Disk or drum? When was the last brake job?
Old 06-16-2007, 12:42 AM   #4 (permalink)
View jackie_ae's Photo Gallery
what brake pads are you using?? some cheap pads are like that. they really squeak even if they are'nt worn out yet and sometime looses grip which is really scary. use Toyota Genuine brake pads instead.
blog!
jackie_ae is offline   Reply With Quote
Old 06-16-2007, 02:23 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
toyota OEM pads arent the best out there.
Old 06-16-2007, 03:45 AM   #6 (permalink)
View toyota_b's Photo Gallery
if this would be the case the oem would be better than the cheap o's from autozone
Here is a link that a few guys recomended as far as brake pads go http://www.toyotanation.com/forum/sh...09#post1803409
toyota_b is offline   Reply With Quote
Old 06-20-2007, 07:30 PM   #7 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
are your brake pad shims installed? if not, get them installed
if that doesn't work, check your rotors for wear...sometimes pads erode the rotors so badly that they cut grooves and cause squeaking...in which case, u have to end up machining your rotors and changing pads (pads and rotora wear together so it's best u get new ones when u machining the rotors
Hook is offline   Reply With Quote
All 4 Disk Breaks Tankedcook Camry & Solara Lounge 13 01-12-2006 07:55 PM
98 Celica GT-S (Opinions) elvasoshexai General Discussion 13 08-11-2005 07:58 PM
'98 Tercel... Yotalicious Tercel, Paseo, Starlet, and Sera Forum 7 02-03-2005 12:43 AM
98 auto corolla vs. 98 Protege Dicipleofthelie General Discussion 8 11-09-2004 05:38 PM
Squeaky Suspension and Breaks... FrankXT86 Camry & Solara Lounge 3 07-05-2003 05:47 PM
