Front end problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2007, 07:26 AM   #1 (permalink)
View cashcrazy's Photo Gallery
Front end problems
I have a 99 corolla and I want the suspension tight again like new. I have 120k. When I hit a series of small bumps There is a rattle from the from the front 2 wheel areas. It sounds like the struts are bad. I replaced 1 front strut and went on a test drive to see if the problem was corrected and the sound is still there. Before I replace the front passenger strut I would like to know exactly what is wrong so I can replace all at once. Could this possibly be a the wheel hub bearings? I have never had a Toyota do this so I am unsure. IF anyone has replace the front wheel bearings, is the hub sold as a unit with bearings?
cashcrazy is offline   Reply With Quote
Old 06-16-2007, 08:49 AM   #2 (permalink)
4wd TN user
View Rolla86's Photo Gallery
How is the rattle? I mean, is too loud? or is just like a screech?
1998 Rolla CE, 5 speed, TSW rims ==>> SOLD
1996 Camry LE, 5 speed 5SFE ==>> SOLD
1993 Pick-Up 4wd SR5, 3VZE, 5 speed, 32x11.50 BFs on 99 4Runner wheels ==>> SOLD
1996 T100, 4wd, 5VZFE, 5spd, 15" Alcoas, 260k in the clock and going for more
Rolla86 is offline   Reply With Quote
Old 06-16-2007, 08:36 PM   #3 (permalink)
Its really hard to explain. It is not a screech or a squeel. It sounds like something is loose. I have had old trucks with bad wheel bearings and (on a jack) the wheel hub could move back and forth(toward the engine bay and away from the engine bay) when you shook it with your hands. The sound is similiar to that. Turning a worn out CV shaft back and forth will make a similar sound. The sound is not to loud like something is about to break but at the same time it is not so quite that you have to turn everything off to hear. It has been doing it for a couple months. I am about to go back to school and I will be on the road alot so I need to get this fixed ASAP. Any help will be appreciated.
Old 06-21-2007, 04:27 PM   #4 (permalink)
still stuck in a rut
Old 06-21-2007, 07:10 PM   #5 (permalink)
You asked for it...
View azcorolla's Photo Gallery
Since you metioned all those other items like ball joints, cv joints ,etc., I assume you've ruled them out.
Could be a strut mount. I had a loose one, and the mechanic checked the whole front end before he got around to the mount. It rattled like there was a loose bolt somewhere.
azcorolla is offline   Reply With Quote
Old 06-22-2007, 05:39 PM   #6 (permalink)
View kwchoi's Photo Gallery
how do you check the strut mount?
kwchoi is offline   Reply With Quote
Old 06-22-2007, 06:26 PM   #7 (permalink)
View Ninja7's Photo Gallery
It could also be your inner tie rods that are shot.
Ninja7 is offline   Reply With Quote
Old 06-23-2007, 07:42 PM   #8 (permalink)
The TN Member
View punter's Photo Gallery
Could be any number of things, do suspesion shops in your area do free checks? most over here do.
Other likley possibilities are, Sway bar end links and Sway bar bushes.
You can't diagnose a rattle over the internet, so you should get some real world help.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
ae92 usdm front end for sale corollaguy86 Car Parts for Sale 1 02-20-2007 01:16 AM
gen 3.5 front end to gen 3 louie1086 3rd & 4th Generation (1992–1996 & 1997–2001) 12 02-02-2007 08:43 PM
Front end "wobbles" severly mrb1962 Archived Corolla threads 0 02-02-2007 02:01 PM
front end problems SnowCindy 89-95 Toyota Pickup/Hilux 2 01-06-2007 07:20 PM
JDM front end 94_Rolla_Guy Archived Corolla threads 11 09-05-2005 09:55 AM
