4A FE Missing Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2007, 06:19 PM   #1 (permalink)
View rizy102's Photo Gallery
hi,
have a corolla, 1.6 93. basically it is not running right and is missing. changed spark plugs, ignition leads, distributor cap, o2 sensor, but still engine is missing. checked each cylinder by removing ignition leads whilst car is on and no. 3 is the one that is not firing. i take the lead out and no change whatsoever. when i take the other ones out the engine starts stuttering etc even more.
anyone have any ideas????
ps. the engine was changed a couple of years back and instead of a corolla engine, a carina engine was fitted. still 4afe though. was running right, then one day started doing this!!!!
thanks
rizy102 is offline   Reply With Quote
Old 06-17-2007, 10:41 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
on #3 does the plug get wet or stay dry?
Old 06-17-2007, 11:32 PM   #3 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
It's probably not missing, the 4afe is jsut a tiny girly little motor, get out a magnafying glass, it's probably there and you just can't see it.
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
Old 06-18-2007, 06:00 AM   #4 (permalink)
plug gets wet.
also, sometimes the car drives fine. it happenes sometimes, and sometimes its perfect.
thanks
Old 06-18-2007, 06:02 AM   #5 (permalink)
View david in germany's Photo Gallery
CHeck the compression.. Same thing happend to me when a valve burnt on my 4a-fe celica.
I am in my own little world but it's ok they know me here!
david in germany is offline   Reply With Quote
Old 06-18-2007, 07:09 AM   #6 (permalink)
hi thanks for the reply.
shall i just go to any garage and ask them to do a compression test???
Old 06-18-2007, 11:06 AM   #7 (permalink)
Bitter's Avatar
if the plug is wet when that cylinder isnt getting spark but is getting fuel. what you need to do is figure out why that one cylinder isnt getting spark or is getting spark at the wrong time. check for moisture, make sure the wires are on in the right order, and in a very dark place watch the engine bay for arcing wires. did you remember to change the rotor as well as the cap?
Old 06-18-2007, 11:26 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
check wires resistance first.
Old 06-18-2007, 03:52 PM   #9 (permalink)
hi, did not change the rotor. will try that tomorow. wires are brand new. how do i check wire resistence???
sorry for my lack of knowledge!!!
Old 06-18-2007, 05:13 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
with a multimeter.
Old 09-20-2007, 03:26 AM   #11 (permalink)
View probsy's Photo Gallery
Australia idk??lol
idk about that but if ya get a tickin sound go straight 2 ya big end.lol i know mine just done it,lol,
probsy is offline   Reply With Quote
Women missing since she was 14 found Bamataco Off Topic 9 03-27-2006 03:58 AM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 04:02 PM
4a fe head on 4age block fleetwood dicki Hardcore Tech and Competition 3 02-15-2005 12:03 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
