which is better...??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2007, 04:56 AM   #1 (permalink)
View ekamakk4agze's Photo Gallery
what turbo will best fit a 4agze T25 or a T28...??
ekamakk4agze is offline   Reply With Quote
Old 06-19-2007, 06:13 AM   #2 (permalink)
View micro214_kp61's Photo Gallery
T28
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 06-19-2007, 06:13 AM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Both will do fine, T28 would be my pick.
Normally you first chose your goals (HP, RPM) then you choose an appropriate size turbo.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 06-19-2007, 07:09 PM   #4 (permalink)
View ManoNegra's Photo Gallery
Spec V T28 from a Nissan S-15. Good for ~300hp with supporting mods. Pics of your manifold please.
ManoNegra is offline   Reply With Quote
Old 06-19-2007, 11:19 PM   #5 (permalink)
aww ok.. i read in phils bradshaw website that a ct26 will also do..? from a 3sgte right..? what will be the diff. between the ct26 from the t25 or t28..? i have a manifold of a 4age N/A....
Old 06-20-2007, 10:36 PM   #6 (permalink)
The TN Member
CT26 is smaller, and will make less power. Depends what you're after.
A CT26 would be a good match for a stock 4agze as the injectors will run out about the same time as the turbo (about 150kw)
Old 06-21-2007, 09:27 PM   #7 (permalink)
i m wondering on what HP will i reach if i put a gt28 turbo on my stock 4agze.... and what must i modify to reach 200hp on a turbo..?? what parts do i still need to reach that HP... tnx...
Old 06-21-2007, 10:53 PM   #8 (permalink)
The TN Member
for 200hp, wouldn't need anything else, run standard GZE ECU.
Old 06-21-2007, 11:22 PM   #9 (permalink)
i just have to put a gt28?? i dont need to change the cams, cam gears.. etc....??
Old 06-22-2007, 12:07 AM   #10 (permalink)
The TN Member
Stock internals are good for 200kw, and about 18~20psi.
But stock GZE ECU is only mapped to 14~15psi so you have to keep it around there.
So yea, just sortout an exhaust + manifold,
intercooler and piping,
and the intake + intake manifold will need to be changed.
Keep the boost under 15psi and it will go great. Would probably only need 11~12 for 200hp.
Old 06-22-2007, 12:18 AM   #11 (permalink)
ahh ok.. thats with a gt28 right.. will the stock turbo from a rb20 work as well?? and what rpm do you thing it will start to spooll and and achieve full boost??
Old 06-22-2007, 12:26 AM   #12 (permalink)
The TN Member
Not sure on an RB20 turbo, that's a T3 right?
The exhaust side of that turbo is often used on hybrids for 4agte's so I guess that means the compressor is smallish.
Still if you're only after 200hp I sure you'd get it.
Old 06-22-2007, 12:38 AM   #13 (permalink)
which would you get a ct26 or t3 from a rb20? my dream HP is 200-250HP..
Old 06-22-2007, 01:36 PM   #14 (permalink)
Gameroom cash: $134355
a t28 from a dsm on a properly tuned megasquirt showed a little higher than 230whp and 220wtq in an mr2..... and the powerband was NOT peaky at all....
a ct26 is a bigger turbo than a t28..... and the spool time will be longer.... which relates to slower lower rpm's and peaky higher rpm's.....
i believe this run was BEFORE he had the power he does now.... numbers were considerably lower
http://www.supermotors.net/vehicles/...y/media/136411
Old 06-22-2007, 11:11 PM   #15 (permalink)
woww... that was a 4agte? what turbo did he use??
