Power mirror/switch install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2007, 03:06 PM   #1 (permalink)
View 97Whitecorolla's Photo Gallery
Question Power mirror/switch install
My wifes car didn't come with power mirrors,so I decided to put some in.I already have the Oem switch and Oem powered mirrors.I thought that the car may already be pre-wired for the mirrors,but I don't see anything.Would a Haynes manual tell me what wires are what? or does sombody alrwady know?Thanks
97Whitecorolla is offline   Reply With Quote
Old 06-24-2007, 03:08 AM   #2 (permalink)
View toyota_b's Photo Gallery
Need model year and type. You might have to get a diffrent panel for the door that would make it look original, however i am not sure if it is located on the drivers door or on the dash/consol. A wiring harness from a car that came with the power windows would be helpful because on some cars they come with the wiring already there just no switch, and posibly with a fuse (if there is a place in the fuse box)
toyota_b is offline   Reply With Quote
Old 06-24-2007, 03:57 PM   #3 (permalink)
I have the oem switch for the mirrors already installed.It went beside the dimmer for the dash lights.The switch has part of the harness already on it,I just dont know which wire is which.
Old 06-24-2007, 06:06 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295873
View Buurin's Photo Gallery
EDIT: I'm assuming a base 97 from his screen name.
You may need to tear down the door interior panel to see if the wire is already there. It may not be there. But you won't need to change the panel unless you decide to put in power windows.
If you look at the oem switch connector and find 8 positions (they should be numbered right on the plug), the pins are -
1-left side left/right
3-ground
4-left side up/down
5-right side left/right
6-right side up/down
7-common (connect to brown/red wire of mirror)
8-+12v
From my Haynes manual.
HTH and good luck.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-24-2007, 06:56 PM   #5 (permalink)
3-ground
4-left side up/down
8-+12v
HTH and good luck.
Thannnnnnkkk yOUUUUUUUU! I had power windows put on her car along time ago,so I'm not worrired about that. I'm still waiting on the mirrors to arrive,how many wires will they have? Will the wires on the mirror match up(color)with the switch? I see that #8 is power,#3 ground? I assume that I would just need to run wires from the passengers side to hook up to the drivers side,then tie into the switch?Thanks
Old 06-24-2007, 07:02 PM   #6 (permalink)
From what I have seen online ,it appears that the left remote mirror wires are.....(1)Blue left/right (2)Lt grn up/dn and right mirror....(1)red left/right (2)red/grn up/dn
Old 06-24-2007, 10:03 PM   #7 (permalink)
Beware of pigs
Buurin's Avatar
Don't worry. Probe the mirrors with +12V to be sure. There will be a third wire for common - you should know where to tie them.
Buy my parts
Buy my other stuff
Old 06-25-2007, 04:04 PM   #8 (permalink)
Hmmm. I didn't see any numbers on the switch itself,but I think i'll be able to figure it out.
Old 06-25-2007, 04:22 PM   #9 (permalink)
Beware of pigs
Buurin's Avatar
Look at the plug, not at the switch. Flashlight helps.
Buy my parts
Buy my other stuff
Old 06-25-2007, 04:29 PM   #10 (permalink)
Ok. I'll go check.
Old 06-25-2007, 05:40 PM   #11 (permalink)
Ok. I looked everywhere on the plug and didn't find any numbers. The plug wire colors are as followed.....One side has three places for wires,but they are only two and they are blue and white/blk The other side has five wires and are green,red,red/grn,brn/rd and gray.
Old 06-26-2007, 08:49 AM   #12 (permalink)
Beware of pigs
Buurin's Avatar
Blue is #1
#2 is no wire
White/black is #3
Brown/red is #7
You can figure out the rest.
Buy my parts
Buy my other stuff
Old 06-26-2007, 03:35 PM   #13 (permalink)
Thanks you! It's Appreciated!!!!
Old 06-27-2007, 02:19 PM   #14 (permalink)
Beware of pigs
Buurin's Avatar
Tell us whe you get it working! And don't forget pics!
Buy my parts
Buy my other stuff
Old 06-27-2007, 03:14 PM   #15 (permalink)
No problem,I'll post some pics. I got the mirrors today and they look great.I'm going to paint them a gloss black.The drivers is a flat black and the passengers is a gloss black,anyways I got both of them for 50.00(new) and the dealer wanted 75.00 for one. The mirrors have three wires a.... white,blue and yellow.Any ideas as to which of those wires go where?Thanks
Gen 1 Avalon stereo install help thread sickwilly 1st Generation (1995-1999) 67 03-05-2012 01:39 PM
Official SMT-6 piggyback install guide for 3vz-fe's Toysrme Camry & Solara Lounge 9 10-12-2010 02:28 PM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
