Question on Strut Installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2007, 05:28 PM   #1 (permalink)
View JohnSWA's Photo Gallery
Hi folks,
I've just installed my struts, but I couldn't tighten the top mount nut without the shaft turning. I have them installed and just gave it a test drive. I've got some serious noise in the strut area and I'm pretty sure it's the struts. The castlated nut would tighten, but both sides would not tightent to the point to where I have threads past the nut head. How do I tighten the nut without the shaft turning?
Thanks!
JohnSWA is offline   Reply With Quote
Old 06-26-2007, 08:33 PM   #2 (permalink)
Hmmmm. No suggestions?
Old 06-26-2007, 08:50 PM   #3 (permalink)
View AVANT's Photo Gallery
You'll have to be creative, take pics if you want more help.
On VW's that I've installed suspension on, when the shaft turns, we take an allen key with an elbow to hold the shaft still (the inside of the shift is shaped as such). We made sure the alley key was longer than the socket that will tighten the top nut so we can put the allen key through it. Using 2 vice grips, one turns the nut while the other holds the allen key still. Yes it became a 2 person job .
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 06-26-2007, 08:50 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Use channel locks to grab the top of the shaft and then tighten. It's VERY important you fix this since thats what holds the force of the spring!
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-26-2007, 09:07 PM   #5 (permalink)
Thanks guys! I got some advice from a bass fishing site of all places! They recommended I use my impact wrench! I know that's not the best way to go for torque ratings and all, but by golly it worked! Now my baby is smooth as silk! Thanks for the help as usual. I really love this site!!!!!
Old 06-26-2007, 09:10 PM   #6 (permalink)
I'd be lying if I said I've never done that as well Impact wrenches can be catastrophic to a car if the user has no idea what he/she is doing tho.
Old 06-26-2007, 11:38 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
Impact wrench? I call it an Impact gun... If I am thinking about the same tool.
Thats how I did mine, thats how shops do them... I made the mistake of thinking you were already using an impact gun lol. Even then sometimes you need the channel locks
Old 06-27-2007, 12:16 AM   #8 (permalink)
The TN Member
View punter's Photo Gallery
Can you not just hold the tophat? There is a flat edge on the thread of the shaft that locates it in the tophat.
Just hold the tophat with one hand to stop it rotating and tighten the nut.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 06-27-2007, 10:22 AM   #9 (permalink)
View tashirosgt's Photo Gallery
The problem of the top mount turning may be due to the fact that the square part of the strut shaft is not seated in the square hole of the mount - at least that's what happens on AE92 front struts. On that kind of strut there should be no such problem at all when the mount is actually seated. Even if you tighten the nut the mount may be riding too high on the strut shaft. On a bumpy road you will hear noise when the mount momentarily seats and unseats itself. If you put a board down in your driveway and drive over it until you are lucky enough to get the mount to seat, then you can tighten the nut all the way down. If that doesn't work, you may have to take the strut off and recompress the spring. Try to do things so the mount slides down and seats properly. It's hard on the AE92.
tashirosgt is offline   Reply With Quote
Old 06-27-2007, 10:29 AM   #10 (permalink)
View Ninja7's Photo Gallery
I use an impact wrench as well.
Ninja7 is offline   Reply With Quote
Old 06-27-2007, 10:58 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
DO NOT DO THAT! You're making scratches on the smooth chrome surface, two things will happen, 1)corrosion will set in, 2) the scratches will kill the upper seal very fast.
Theres the flat part on top of the strut, thats there to put a spanner to hold the strut still. Some have a allen key hole on the top.
Old 06-27-2007, 12:58 PM   #12 (permalink)
View igorien2k's Photo Gallery
hold the strut shaft with a strap pipewrench, not the metal kind. then you can tighten it
igorien2k is offline   Reply With Quote
Old 06-27-2007, 02:28 PM   #13 (permalink)
Vroom?
freakinbox's Avatar
Some have nothing and you don't do it at the very bottom ... you hold it at the top. If your strut is going that far in then you don't have a spring? The very top of the strut doesn't actually go in. As for the corrosion, I think your underestimating the corrosion resistance as think how many rocks ping them
you can also use something with a rubber grip, or a rag which should still give it enough resistance, if not you may need to clean the threads or nut.
Old 06-27-2007, 04:36 PM   #14 (permalink)
Resident asshole
Flashmn's Avatar
When you have the rubber boots on, rocks dont "ping" them. I'm not talking about the shock body, I'm talking a bout the chrome rod.
Oh and my shocks do go almost all the way. I had to take out the bumpstops because my car was resting on them. I think if the ride sucks, I'm gonna have to shorten my shocks, but since they're upside down struts its gonna be tricky.
Old 07-04-2007, 10:11 PM   #15 (permalink)
View meicalnissyen's Photo Gallery
shit
two issues
you have a thread locker nut thata was too stiff
you f'd up the flat side of the stock camber plate and have visited spin ciy
the noise is a bit of slack along the strut shaft whackin the camber plate VERY annoying but not life threating
meicalnissyen is offline   Reply With Quote
Question on Strut bars rockhard 1st & 2nd Generation (1983–1986 & 1987-1991) 7 10-24-2009 10:07 PM
struts abew330 Camry & Solara Lounge 2 02-14-2007 01:38 PM
Question on rear strut replacement adamcbc 3rd & 4th Generation (1992–1996 & 1997–2001) 13 10-15-2006 09:06 AM
Strut question, for those with KYB GR-2 Gen3cruiser Camry & Solara Lounge 6 06-15-2004 09:02 AM
Same Question! I'm sorry everyone! Vampress Camry & Solara Lounge 2 05-17-2003 09:30 PM
