100 amp fuse blows
Hi, I'm new to the forum, but have had a Corolla for ten years. I've developed a problem and was wondering if anyone else has run in to this. The car is a 97 and the 100 amp fuse to the alternator blew. The alternator was replaced as well as the fuse. One month later, after hitting a bump, the same thing happened. I replaced the fuse and checked the alternator, which was good. I suspect an intermittent short due to either a loose wire hitting a ground or a frayed wire doing the same thing. If anyone has had this problem I'd appreciate any help you could give. Thanks.
Rob
