oil pump porblem?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2007, 01:28 PM   #1 (permalink)
View christian777's Photo Gallery
oil pump porblem??
I have a 1991 Prizm with 131k. Recently the oil pump idiot light started flashing intermittently at any engine RPM under 2k- the lower the rpm, the more the light stays on. The oil pan is full. Is this a sign to replace the oil pump? Possibly a sensor isssue? Please let me know. Thanks!
Christian
christian777 is offline   Reply With Quote
Old 06-29-2007, 01:35 PM   #2 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
I would replace the oil sender switch behind the alternator first and if that does not fix it then the oil pump.
91boz is offline   Reply With Quote
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 01:09 PM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 09:44 AM
performance oil pump? profitwho007 Camry & Solara Lounge 5 01-24-2005 01:53 PM
1990 ES250 Oil Pump seal ArmyofOne 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-11-2005 06:46 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 11:48 AM
