99 Corolla suspension noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2007, 08:30 PM   #1 (permalink)
View MoboTech's Photo Gallery
I'm getting a creaking noise whenever I push on the gas and when I'm slowing down to stop, its sounds like its coming from the front suspensions only, any idea how I can fix this and place to buy the parts?
thanks.
MoboTech is offline   Reply With Quote
Old 07-04-2007, 10:22 PM   #2 (permalink)
View meicalnissyen's Photo Gallery
clack
well what are you runnin,,,, stock, or what?
could be spring perches, or also the strut tower area
I have had this bitch apart in this area and can probably answer this one. give me details
meicalnissyen is offline   Reply With Quote
Old 07-06-2007, 11:59 AM   #3 (permalink)
Its a stock, usually when their's pressure applied to the suspension, it will make that noise.
Old 07-08-2007, 12:55 PM   #4 (permalink)
hhmmm
well, with power and brake applied, you get some opposing twisty forces. assuming "clack" noise, I would check the upper strut mount its under the rubber cap the nut may have loosened allowing some play.. there are other places to have slop, but that is most likely
Old 07-08-2007, 04:32 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
The spring would keep it under tension, so it wouldnt be that... something else bushings maybe.
Rear suspension noise tlwills 2nd Generation (2000-2004) 10 11-01-2011 09:30 PM
Noise from gas tank with Corolla 2006 neeco80 Archived Corolla threads 6 11-21-2006 10:02 AM
Strange noise when closing door with Corolla 2006 CE neeco80 Archived Corolla threads 5 09-27-2006 08:47 AM
89 corolla coupe road noise problem bowtomecha Archived Corolla threads 6 03-17-2005 04:21 PM
99 Corolla Drive Belt Noise bedrock4x Archived Corolla threads 2 04-08-2002 05:45 PM
