Idles too fast - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2007, 05:30 AM   #1 (permalink)
View sydjf's Photo Gallery
Australia Idles too fast
Gooday everyone,
I have an AE82 that has run out of idle adjustment. I have replaced all vacuum lines and then I checked that the automatic choke is opening all the way when the engine is warmed up, but it is still idleing too fast. As a result it wants too 'diesel' when I switch the engine off. I am pretty sure the fuel cut solenoids are okay as I tested them manually and it sounds like they are 'clicking' fine. Thanks in advance for anyone who might have any ideas.
sydjf is offline   Reply With Quote
Old 07-02-2007, 09:35 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
try cleaning the carb up with some carb cleaner and re adjusting it.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 07-02-2007, 11:49 AM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Check your timimg. Sounds as if it ight be advaned.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 07-02-2007, 06:05 PM   #4 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Originally Posted by sydjf
Gooday everyone,
does that model have VSV's on the vacum lines?
still sounds like a vacum problem..
retiredat44 is offline   Reply With Quote
Old 07-03-2007, 02:12 AM   #5 (permalink)
Australia reply
I have experimented with the timing by adjusting it anywhere between 5 degrees to 15 degrees to see if it makes much difference to the idle revs . It does make a small diference but not enough. Carb has been thoroughly cleaned.
To retiredat44, what are VSV's.
Thanx for the replys.
Old 07-03-2007, 12:02 PM   #6 (permalink)
Exclamation
VSV's = vacum control switches (with electronics), some for emissions,, others for other stuff..
Old 07-03-2007, 05:42 PM   #7 (permalink)
Donald's Avatar
Dieseling and high idle are classic symptoms of advanced timing, but if you have already checked that, the next thing I'd check is for a vacuum leak.
Retiredat44 has a good idea with the VSVs.
Is your car carb or FI?
Old 07-04-2007, 02:31 AM   #8 (permalink)
Australia reply
I will check the VSV's and see how that goes. My car has a carby.
Thanx for the advice.
car indicators flashing fast migoreng General Discussion 9 08-16-2005 06:15 PM
Fast food places you will never eat at again? kenratboy Off Topic 33 07-17-2004 08:13 PM
My engine idles fast TRDragoon Hardcore Tech and Competition 12 05-12-2003 07:43 PM
Fast Food Voodoo.Priest Off Topic 22 04-17-2002 09:29 AM
