7th gen stiff motor mounts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2007, 07:22 PM   #1 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
I cant find any stiff mounts or mount inserts for my 93, are none made or are there inserts for another car that will work? i mostly just want a front insert thats stiffer than stock. its 78mm across and 38mm wide with the the through bolt in the center.
Old 07-05-2007, 08:03 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
I was looking into that window weld stuff which to me looked and sounded kinda hoaky so i went on a hunt and i found this stuff..
http://www.devcon.com/devconfamilypr...d=151&catid=14
It should work, just be careful of the durometer (how hard or soft it is\
To do it i suppose you could just fill around the rubber but my preference would be too remove the old rubber and totally re-cast the mounts
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-05-2007, 10:59 PM   #3 (permalink)
Bitter's Avatar
i've heard some bad stories about home cast mounts just breaking, the material simply cracks. even some profesionally made urethane ones just crack, and after handling the material used to make the mounts from, i can totally understand why. to get the hardness desired, its pretty easily broken stuff. it doesnt flex, it breaks. now the inserts i just installed on a guys eclipse felt more like hard vinyl then urethane and were very tough material that didnt seem like it would sheer easily at all.
that material you linked was exactly what i was looking at, and its what i've seen some people use and then break as well.
Old 07-06-2007, 10:50 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I made mine from Polyurethane seam sealer
Cost me 7.40euros a tube, used one tube.
Old 07-06-2007, 07:43 PM   #5 (permalink)
Bitter's Avatar
how long have they lasted you?
Old 07-07-2007, 11:05 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
I havent driven with them yet, because my car is undergoing work, but I'm pretty sure they wont have any problems lasting. They're solid, so they dont have any chance to crack.
Old 07-07-2007, 12:19 PM   #7 (permalink)
Bitter's Avatar
those are the kind that i've seen break most often tho, the solid ones. but the material used to fill them was a more brittle urethane or over time and exposure to heat and constant stress the urethane became brittle. so whats the manufatuer of the gunk you used to fill it and the name of their product?
Old 07-07-2007, 02:08 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Würth polyurethane mass. It remains flexible.
Old 07-07-2007, 07:20 PM   #9 (permalink)
Bitter's Avatar
hmm i'll give seam sealer a try, thanks! its about $15 a tube.
Camry Photo Online Site... -SCWEET1- Camry & Solara Lounge 98 03-05-2008 03:06 PM
CAMRY COUPE part out! **take this stuff from me and build another camry with it** felkajamine Car Parts for Sale 122 02-07-2008 10:18 PM
7th gen celica TRDGTS6SPD Celica Forum 10 07-11-2005 12:00 AM
new all trac 7th gen??? urbandork Celica Forum 3 06-16-2005 06:55 PM
